installing gauges, need help/advice wiring oil temp and pressure gauges |
914 RZ-1 |
Jul 15 2016, 02:56 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
I got oil pressure and oil temp gauges. The instructions are generic and I'd like some specifics about how to install them on my 1.7L '72. Sorry if these seem obvious; I've never done this before.
1. Standard ground or floating ground? I'm leaning toward floating because it looks obvious how to attach the ground. On the standard ground, how do I attach the gnd wires? 2. What do I attach the wire from the gauge light socket to the light switch to? The headlight switch? Which connector? 3. Which fuse do I use for power? #9? 4. I figure I will just attach grounds to a screw on the body, either an existing one or a new one. 5. What is the "switched +12v" light shown in the instructions? The dummy light? 6. Does the oil pressure sensor get installed where the current oil pressure switch is by the distributor? Doesn't appear to be any room, but I'll need to move some hoses, etc out of the way. 7. Where does the oil temp sensor go? The instructions state that it can replace the drain plug. Is this correct? 8. Where is the best route for the wires? I was thinking thru the middle along where the other wiring harness is located. What should I do with them in the engine compartment: zip tie them to other wires, or let them hang free, or what? If anyone has done this and has pictures or a more detailed description, I'd appreciate it. Attached thumbnail(s) |
914 RZ-1 |
Sep 16 2016, 08:34 PM
It seems the oil temp gauge works. I drove the car for 20 minutes and it went to almost 180. The sensor is under the car and not covered, so the air probably cooled it. I'm just going to assume the oil is hotter than that. Probably should get a temp gauge and try to measure it somehow. Any thoughts on how to do this?
The oil pressure still pegs to the right. I'm pretty sure I hooked it up right, but clearly something is wrong. Any ideas? (IMG:style_emoticons/default/headbang.gif) The lights on the gauges don't work either. I tapped into the lighting wires for the other instruments. Does it matter which wire or wires I use? Here are some pics: Attached thumbnail(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 04:56 PM |
