Custom Raised Console, Like this interior? |
oakdalecurtis |
Jul 15 2016, 10:02 PM
Oakdalecurtis Group: Members Posts: 1,325 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
Anyone like this custom raised console? I can drive and shift with my right arm supported at all times, it opens with lots of storage space inside, and it has a cupholder bar in front of the box in the tray. I had to add short seat belt extensions on each side to reach the belt latches. The shifter has been moved slightly to the left, the smaller Momo wheel gives my 6'3" legs lots of room now. A steering wheel spacer raises the steering wheel by about an inch so I can still see the gauges properly. You like the yellow Blaupunkt radio?
bandjoey |
Jul 15 2016, 10:23 PM
bandjoey Group: Members Posts: 4,925 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Cool Interior. Pictures of the cup holder and insides? Did you just build a new bottom box or add to the existing one?
oakdalecurtis |
Jul 15 2016, 10:31 PM
Coondog |
Jul 15 2016, 10:36 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
Must have been your favorite TV show as a kid......... (IMG:style_emoticons/default/poke.gif)
914Sixer |
Jul 16 2016, 06:29 AM
AMCO aftermarket console had a raised end like yours. It was great item for cars with out the factory console.
jrblackbox |
Jul 16 2016, 06:57 AM
Member Group: Members Posts: 285 Joined: 8-September 15 From: Easton, CT Member No.: 19,140 Region Association: None |
Anyone like this custom raised console? I can drive and shift with my right arm supported at all times, it opens with lots of storage space inside, and it has a cupholder bar in front of the box in the tray. I had to add short seat belt extensions on each side to reach the belt latches. The shifter has been moved slightly to the left, the smaller Momo wheel gives my 6'3" legs lots of room now. A steering wheel spacer raises the steering wheel by about an inch so I can still see the gauges properly. You like the yellow Blaupunkt radio? Info on the seat inserts please, and all you need now to set it off are some yellow face gauges! (IMG:style_emoticons/default/smile.gif) |
oakdalecurtis |
Jul 16 2016, 09:26 AM
Anyone like this custom raised console? I can drive and shift with my right arm supported at all times, it opens with lots of storage space inside, and it has a cupholder bar in front of the box in the tray. I had to add short seat belt extensions on each side to reach the belt latches. The shifter has been moved slightly to the left, the smaller Momo wheel gives my 6'3" legs lots of room now. A steering wheel spacer raises the steering wheel by about an inch so I can still see the gauges properly. You like the yellow Blaupunkt radio? Info on the seat inserts please, and all you need now to set it off are some yellow face gauges! (IMG:style_emoticons/default/smile.gif) Seat inserts were custom made by local upholstery shop long ago, can't remember which one, but very simple to make. |
whitetwinturbo |
Jul 16 2016, 09:28 AM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
andys |
Jul 16 2016, 09:50 AM
I made a custom console, and elevated the arm rest. I always felt the stock height was somewhat useless. I now have a usable and comfortable arm rest.
Andys Attached thumbnail(s) |
Lo-Fi Version | Time is now: 13th May 2024 - 04:25 PM |
