3rd Brake Lamp, my best try..., Now bigger and better! 2019 |
Garland |
Apr 9 2005, 10:20 PM
Restoration Fanatic Group: Members Posts: 1,329 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
Well can you see it?
Attached image(s) |
Garland |
Jul 23 2019, 05:59 PM
I’ve been wanting to extend the third brake lamp for more width. So this time I’m using the lamp from a Cadillac tailgate . I had to extensively modify the lens size, by filing and sanding it to fit inside the 914 trim. I wanted to reinforce the rollbar and give a backstop to the lamp, so I utilized some underlying material used for floating floors inside the roll bar. It also took quite a bit of time to shave/mill the hole in the roll bar trim.
Also I used the reflective material to get the best performance from the lamp. Do to do the additional depth needed for the lenses and the style lamp, I needed a little more height, the trim is mounted ontop of the pinch weld, instead of over it. The center section of the pinch weld I removed when installing the other lamp, so a set screw at each end holds the trim in place. |
Lo-Fi Version | Time is now: 19th May 2024 - 02:21 AM |
