3rd Brake Lamp, my best try..., Now bigger and better! 2019 |
Garland |
Apr 9 2005, 10:20 PM
Restoration Fanatic Group: Members Posts: 1,329 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
Well can you see it?
Attached image(s) |
euro911 |
Jul 23 2019, 08:59 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,849 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
I have a spare crossbar trim piece and plan to do pretty much the same thing with a wide LED strip. My only fear is cutting the opening - not sure of the best method to accomplish the task.
I don't think my hands are steady enough to try it with a Dremel tool (IMG:style_emoticons/default/dry.gif) Should I make a fixture to hold the trim piece and use a router with a small diameter bit? ... ... or make a fixture and attempt to run it through a vertical mill? |
Lo-Fi Version | Time is now: 19th May 2024 - 12:41 AM |
