Weber 40 IDTP Parts |
xsurfer |
Jul 21 2016, 08:44 AM
Member Group: Members Posts: 279 Joined: 4-April 06 From: La Canada, CA Member No.: 5,818 |
I need a source for 40IDTP parts. One float dented, idle jet carrier cracked on first
carb. Can't get the large caps on top loose. Any help appreciated. Thanks |
Mark Henry |
Jul 21 2016, 10:01 AM
The dented float was caused by someone using compressed air on the closed float bowl.
The IDTP is basically an IDA with a few different parts and drillings. http://youroil.net/weber_carb_parts.html |
rgalla9146 |
Jul 22 2016, 06:58 AM
Advanced Member Group: Members Posts: 4,560 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
The dented float was caused by someone using compressed air on the closed float bowl. The IDTP is basically an IDA with a few different parts and drillings. http://youroil.net/weber_carb_parts.html I found collapsed floats in a pair of 40's too Caused (pretty sure) by cupping a hand over the throat on a running engine to clear jets. |
stugray |
Jul 27 2016, 03:57 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
The dented float was caused by someone using compressed air on the closed float bowl. The IDTP is basically an IDA with a few different parts and drillings. http://youroil.net/weber_carb_parts.html I found collapsed floats in a pair of 40's too Caused (pretty sure) by cupping a hand over the throat on a running engine to clear jets. Wait what? I have never heard of that being a bad thing, and wouldnt that 'pop' the float instead of crush it if it were to do anything bad? |
Lo-Fi Version | Time is now: 25th May 2024 - 09:05 PM |
