Weber carb help, Weber Gurus? |
Elliot Cannon |
Jul 24 2016, 06:38 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
I just finished installing an overhaul kit in one of my 44idf's. It runs great now except for a stubborn fuel leak at the large 19mm filter holder plug just next to the fuel intake. The one that holds the small white filter. That one. I can't get it to stop leaking. Not a pouring out leak but a drip per second leak. I tried loosening it, tightening it and using two gaskets together and it still leaks. both surfaces look clean and smooth. Any ideas?
r_towle |
Jul 24 2016, 08:38 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
If with the gasket in place you have a leak, most likely you have some damage of th mating surfaces.
Typically, unless it's a huge gash, the gasket will make up for,the difference... Are you using a gasket there? What type? Is it the right filter or maybe it's holding the part. Just a hair. I know there are what, 10 different accelerator pumps for them....maybe there are multiple filters and you got one too tall. |
Lo-Fi Version | Time is now: 19th May 2024 - 03:56 PM |
