Weber carb help, Weber Gurus? |
Elliot Cannon |
Jul 24 2016, 06:38 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
I just finished installing an overhaul kit in one of my 44idf's. It runs great now except for a stubborn fuel leak at the large 19mm filter holder plug just next to the fuel intake. The one that holds the small white filter. That one. I can't get it to stop leaking. Not a pouring out leak but a drip per second leak. I tried loosening it, tightening it and using two gaskets together and it still leaks. both surfaces look clean and smooth. Any ideas?
r_towle |
Jul 24 2016, 08:38 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
If with the gasket in place you have a leak, most likely you have some damage of th mating surfaces.
Typically, unless it's a huge gash, the gasket will make up for,the difference... Are you using a gasket there? What type? Is it the right filter or maybe it's holding the part. Just a hair. I know there are what, 10 different accelerator pumps for them....maybe there are multiple filters and you got one too tall. |
Elliot Cannon |
Jul 24 2016, 09:39 PM
If with the gasket in place you have a leak, most likely you have some damage of th mating surfaces. Typically, unless it's a huge gash, the gasket will make up for,the difference... Are you using a gasket there? What type? Is it the right filter or maybe it's holding the part. Just a hair. I know there are what, 10 different accelerator pumps for them....maybe there are multiple filters and you got one too tall. I thought it might be the filter but it's the same filter that was in it. The one in the overhaul kit was damaged. Both mating surfaces seemed clean and smooth. Interestingly, the one on the other carb. was leaking as well. Tightened it a little and the leak stopped. Could be that the gaskets just got dry?? The car has sat since the rt66 "freeze your ass off in Arizona tour". (IMG:style_emoticons/default/av-943.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 08:31 PM |
