Weber carb help, Weber Gurus? |
Elliot Cannon |
Jul 24 2016, 06:38 PM
I just finished installing an overhaul kit in one of my 44idf's. It runs great now except for a stubborn fuel leak at the large 19mm filter holder plug just next to the fuel intake. The one that holds the small white filter. That one. I can't get it to stop leaking. Not a pouring out leak but a drip per second leak. I tried loosening it, tightening it and using two gaskets together and it still leaks. both surfaces look clean and smooth. Any ideas?
Elliot Cannon |
Aug 21 2016, 05:03 PM
I think I finally got something that would stop the leak. I bought very thin 1/2 inch mylar washers, opened them up to 9/16, squeezed one of them over the threads of the plug, installed it and so far no leaks. I'm pretty sure the mylar will hold up. I'm told mylar never deteriorates. Ever. (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 30th May 2024 - 12:22 AM |
