Weber carb help, Weber Gurus? |
Elliot Cannon |
Jul 24 2016, 06:38 PM
I just finished installing an overhaul kit in one of my 44idf's. It runs great now except for a stubborn fuel leak at the large 19mm filter holder plug just next to the fuel intake. The one that holds the small white filter. That one. I can't get it to stop leaking. Not a pouring out leak but a drip per second leak. I tried loosening it, tightening it and using two gaskets together and it still leaks. both surfaces look clean and smooth. Any ideas?
Eric_Shea |
Aug 21 2016, 05:13 PM
Also, for future work, get an extra 6 sided 19mm and shave it down so the mating surfaces are perfectly square. It helps you get some torque on that fitting without damaging it.
Elliot Cannon |
Aug 21 2016, 05:39 PM
Lo-Fi Version | Time is now: 19th May 2024 - 06:42 PM |
