Wanted pics of 914/6 conversion cable routing solutions, For clutch, speedo and gas cables |
Mark Henry |
Jul 25 2016, 08:43 AM
I would like a few pic's of different solutions members came up with for routing the cables with headers, so they don't get fried or hang down.
Tried a search, but I guess I'm not using the correct boolean terms. Thanks! (IMG:style_emoticons/default/beer.gif) |
GeorgeRud |
Jul 25 2016, 09:12 AM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
The speedo and clutch cables run as they did in the four with a short 'hanger' attaching them to the rear part of the engine. Assuming the accelerator is switched to the 914-6 system with the pull Rod, you can also run it through a hanger to hold it up.
worn |
Jul 25 2016, 10:33 AM
can't remember Group: Members Posts: 3,150 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I would like a few pic's of different solutions members came up with for routing the cables with headers, so they don't get fried or hang down. Tried a search, but I guess I'm not using the correct boolean terms. Thanks! (IMG:style_emoticons/default/beer.gif) Hi Mark, I made this aluminum bracket to bundle things together along the engine centerline. It actually is pretty easy. My biggest problem is the 911 E-brake line. This bundles throttle, clutch and speedo. You can see an adele clamp on the engine as well near the firewall. Sorry, but this is the best picture I already have. |
McMark |
Jul 25 2016, 11:53 AM
I use adele clamps quite frequently.
mb911 |
Jul 25 2016, 07:07 PM
914 Guru Group: Members Posts: 6,823 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
gereed75 |
Jul 26 2016, 05:22 AM
Senior Member Group: Members Posts: 1,241 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
Adel clamps for me. All routed together as a bundle....what helped me is the accelerator cable goes up and over the hard oil line as it comes out of the fire wall, the speedo and clutch go under. More better fit that way (IMG:style_emoticons/default/smile.gif) |
siverson |
Jul 26 2016, 08:12 AM
Advanced Member Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
It really annoys me too when they hang down. Maybe I'll try the throttle cable going up out of the firewall, but that seemed like a tight bend to me.
My "solution" was pretty hacky with adele clamps and cable ties, but works. -Steve Attached thumbnail(s) |
wndsnd |
Jul 26 2016, 10:06 AM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
Mark Henry |
Jul 28 2016, 10:58 PM
My solution so far, I bent a piece of steel tube, split it, opened it up a bit and welded a couple of tabs on.
I still have to figure out better clamps. Attached thumbnail(s) Attached image(s) |
gereed75 |
Jul 29 2016, 07:12 AM
Lo-Fi Version | Time is now: 5th May 2024 - 10:22 AM |
