Best way to lift 914 on hoist?, Will be lifting onto body stand |
aggiezig |
Jul 26 2016, 09:02 AM
Porsche Wannabe Group: Members Posts: 319 Joined: 13-January 16 From: Los Angeles, CA Member No.: 19,557 Region Association: Southern California |
I'm planning on renting an engine hoist today to lift my 914 up onto the body stand I built this weekend.
I saw some posts referencing mounting onto the seat tilt adjust brackets? Are these the two vertical brackets that hold part of the "tooth gear setup" for that connects to the tilt adjuster handle / allows the seat base to move up and down? If so, assuming I will have to remove seat base frames and the gear teeth to access the holes in these brackets. I also thought about just using a tow strap wrapped around the middle of the car? Anybody have ideas / thoughts / pictures? |
aggiezig |
Jul 26 2016, 09:28 AM
Show us a picture of the stand, and car. Is the car complete - have you removed power plant - how much weight are you planning to lift up? The body stand: (IMG:http://www.914world.com/bbs2/uploads_offsite/i120.photobucket.com-19557-1469415983.7.jpg) The car: (IMG:http://www.914world.com/bbs2/uploads_offsite/i120.photobucket.com-19557-1469238833.1.jpg) Engine / trans have been removed since this pic was taken. Trunk hood / decklid are off, interior is out, will take up and remove wheels, etc. Will be getting a 1.5 or 2 ton engine hoist so should not be an issue. |
Lo-Fi Version | Time is now: 18th May 2024 - 11:12 AM |
