Best way to lift 914 on hoist?, Will be lifting onto body stand |
aggiezig |
Jul 26 2016, 09:02 AM
Porsche Wannabe Group: Members Posts: 319 Joined: 13-January 16 From: Los Angeles, CA Member No.: 19,557 Region Association: Southern California |
I'm planning on renting an engine hoist today to lift my 914 up onto the body stand I built this weekend.
I saw some posts referencing mounting onto the seat tilt adjust brackets? Are these the two vertical brackets that hold part of the "tooth gear setup" for that connects to the tilt adjuster handle / allows the seat base to move up and down? If so, assuming I will have to remove seat base frames and the gear teeth to access the holes in these brackets. I also thought about just using a tow strap wrapped around the middle of the car? Anybody have ideas / thoughts / pictures? |
aggiezig |
Jul 26 2016, 10:16 AM
I stole the design / plans from this thread, and he did not appear to have any issues. The stand is actually pretty stout / I don't anticipate any issues. The uprights are only 12" and the triangle braces add quite a bit of lateral support.
Unfortunately, I don't have the luxury of four buddies to help me out so I will be stuck with using an engine hoist and one other friend to help balance while I roll the cart into place. Any tips for lift points for the hoist? |
Lo-Fi Version | Time is now: 18th May 2024 - 09:07 AM |
