Best way to lift 914 on hoist?, Will be lifting onto body stand |
aggiezig |
Jul 26 2016, 09:02 AM
Porsche Wannabe Group: Members Posts: 319 Joined: 13-January 16 From: Los Angeles, CA Member No.: 19,557 Region Association: Southern California |
I'm planning on renting an engine hoist today to lift my 914 up onto the body stand I built this weekend.
I saw some posts referencing mounting onto the seat tilt adjust brackets? Are these the two vertical brackets that hold part of the "tooth gear setup" for that connects to the tilt adjuster handle / allows the seat base to move up and down? If so, assuming I will have to remove seat base frames and the gear teeth to access the holes in these brackets. I also thought about just using a tow strap wrapped around the middle of the car? Anybody have ideas / thoughts / pictures? |
r_towle |
Jul 26 2016, 01:04 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I used an old bumper, welded a hook on it for the hoist.
Second time I did it, I removed the suspension first, then just got a few guys and lifted it by hand.....with no suspension it's maybe 400lbs.... |
Lo-Fi Version | Time is now: 18th May 2024 - 08:14 AM |
