Hot Summer; Hot, Overheating V-8 Radiator Setup., Hot Summer; Hot, Overheating V-8 Radiator Setup. |
BRAVE_HELIOS |
Jul 26 2016, 08:35 PM
"Knowledge speaks, wisdom listens" Group: Members Posts: 295 Joined: 25-September 06 From: The Land Of ID! Member No.: 6,920 Region Association: Pacific Northwest |
Can anyone divulge details on the Renegade Hybrid radiator system such as dimensions, Inlet and outlet sizes and rad type (number of rows, if cross flow etc...). Is it even allowed ;-)?
This hot summer has proven that my system cannot handle it. I have some good components such as a 2000 cfm, 9 blade fan out of a Ford Taurus. The remote mechanical water pump is a standard R.H. unit. I also have a Griffin radiator, model 125241-H... no radiator cap (inlet=1.5" and outlet=1.75"). https://www.summitracing.com/parts/gri-1-25241-x The dimensions are 16"x 27.5" x 3". it is a 2 row unit. Although the inlet/outlet sizes are different, the hoses carrying coolant from front to rear are all the same size at 1.25 inch diameter. The Tech rep at Griffin seems to think that the rad should be fine but I ain't no 4 core unit either. The other part of this is the car has a Chalon kit installed. I question whether the bumper opening for rad air is sufficiently sized. The opening is ducted to the bulkhead opening. The inner fender walls are fully open to allow the air to exit. From all that I've read; the viable solutions is to either go with a RH rad setup (or as close to as possible) and/or go with an electric water pump. I think I have some (most) of what RH would sell me as there rad kit. The only difference I can see is the rad size/type and the bumper opening size. Pictures of my current setup can be found here: http://www.914world.com/bbs2/index.php?sho...132273&hl=# I feel like I am close to getting this figured out. Just a bit more tinkering is needed. Thanks! |
cali914 |
Jul 27 2016, 12:47 AM
cali914 Group: Members Posts: 447 Joined: 26-April 06 From: Berkeley Ca. Member No.: 5,934 Region Association: Northern California |
Can anyone divulge details on the Renegade Hybrid radiator system such as dimensions, Inlet and outlet sizes and rad type (number of rows, if cross flow etc...). Is it even allowed ;-)? This hot summer has proven that my system cannot handle it. I have some good components such as a 2000 cfm, 9 blade fan out of a Ford Taurus. The remote mechanical water pump is a standard R.H. unit. I also have a Griffin radiator, model 125241-H... no radiator cap (inlet=1.5" and outlet=1.75"). https://www.summitracing.com/parts/gri-1-25241-x The dimensions are 16"x 27.5" x 3". it is a 2 row unit. Although the inlet/outlet sizes are different, the hoses carrying coolant from front to rear are all the same size at 1.25 inch diameter. The Tech rep at Griffin seems to think that the rad should be fine but I ain't no 4 core unit either. The other part of this is the car has a Chalon kit installed. I question whether the bumper opening for rad air is sufficiently sized. The opening is ducted to the bulkhead opening. The inner fender walls are fully open to allow the air to exit. From all that I've read; the viable solutions is to either go with a RH rad setup (or as close to as possible) and/or go with an electric water pump. I think I have some (most) of what RH would sell me as there rad kit. The only difference I can see is the rad size/type and the bumper opening size. Pictures of my current setup can be found here: http://www.914world.com/bbs2/index.php?sho...132273&hl=# I feel like I am close to getting this figured out. Just a bit more tinkering is needed. Thanks! Man I went through the same thing with my old small block 914 tried regular water pump, different size hose lines and four different radiators finally I bit the bullet and purchased The Renegade set up with a 55 gallon Meizere water pump which I mounted close to the radiator and the car stayed between 160 and 190 all day long hot or cold days. Another biggie is to have your system where your air gets bled out and fluid is sucked in. The Renegade set up is a little pricey but it's proven especially with them being in Las Vegas and pay the man one time and be done with it. Then you can focus on a turbo set up. LOL (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 09:03 PM |
