Hot Summer; Hot, Overheating V-8 Radiator Setup., Hot Summer; Hot, Overheating V-8 Radiator Setup. |
BRAVE_HELIOS |
Jul 26 2016, 08:35 PM
"Knowledge speaks, wisdom listens" Group: Members Posts: 295 Joined: 25-September 06 From: The Land Of ID! Member No.: 6,920 Region Association: Pacific Northwest |
Can anyone divulge details on the Renegade Hybrid radiator system such as dimensions, Inlet and outlet sizes and rad type (number of rows, if cross flow etc...). Is it even allowed ;-)?
This hot summer has proven that my system cannot handle it. I have some good components such as a 2000 cfm, 9 blade fan out of a Ford Taurus. The remote mechanical water pump is a standard R.H. unit. I also have a Griffin radiator, model 125241-H... no radiator cap (inlet=1.5" and outlet=1.75"). https://www.summitracing.com/parts/gri-1-25241-x The dimensions are 16"x 27.5" x 3". it is a 2 row unit. Although the inlet/outlet sizes are different, the hoses carrying coolant from front to rear are all the same size at 1.25 inch diameter. The Tech rep at Griffin seems to think that the rad should be fine but I ain't no 4 core unit either. The other part of this is the car has a Chalon kit installed. I question whether the bumper opening for rad air is sufficiently sized. The opening is ducted to the bulkhead opening. The inner fender walls are fully open to allow the air to exit. From all that I've read; the viable solutions is to either go with a RH rad setup (or as close to as possible) and/or go with an electric water pump. I think I have some (most) of what RH would sell me as there rad kit. The only difference I can see is the rad size/type and the bumper opening size. Pictures of my current setup can be found here: http://www.914world.com/bbs2/index.php?sho...132273&hl=# I feel like I am close to getting this figured out. Just a bit more tinkering is needed. Thanks! |
Cracker |
Jul 31 2016, 05:51 AM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
Cali: The coolant temp depends on the air temp and whether I'm stuck in traffic or on a race track. On a hot Summer day rolling it will get to 185-190; Hot day stopped traffic - 205; Hot full blown sustained racing - 215-225 (depending upon conditions).
LS engines make their best power HOT; 230 is where you need to really take notice that you have reached the tipping point. All the best. PS: My chassis was a multi-owner water pumper before I ever acquired it...Bob (BigKat) and I have a good friend Larry C. (Spaceshuttle) who I purchased the roller from - Larry did the hood on my car well before I ever bought it. The inner fenders were cut before he purchased it too. I tape off about 90% of the fender venting to force the heat out the hood. JFYI for all... T |
jd74914 |
Aug 1 2016, 07:07 AM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
LS engines make their best power HOT; 230 is where you need to really take notice that you have reached the tipping point. All the best. Tangentially-related to cooling, but hot is actually better for cylinder wall wear per some studies done by Caterpillar so assuming you don't have piston/cylinder head overheating issues (tight clearances, etc.) its better to have a higher pressure radiator cap and run hotter rather than cooler. |
Lo-Fi Version | Time is now: 17th May 2024 - 02:42 PM |
