Need battery charging help and advice!, What should I try next? |
oakdalecurtis |
Jul 28 2016, 06:01 PM
Oakdalecurtis Group: Members Posts: 1,325 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
'76 2.0, I replaced the alternator and installed a new Beru VR. Started car up and it was charging at 18 volts at the battery, no good! I then tried 3 differents used Bosch VR's. (Thank you Dominic!). All of the VR's slid into the relay board socket very loosely, so I tried slightly bending the VR connector tabs to make a better contact. In each case, either the voltage meter reads 12.6 volts (not charging), or it swings back to 18 volts! Also, when I'm pulling the throttle cable to increase engine speed and at the same time I am touching the metal VR case to wiggle it to see if that helps, I can feel a low electric pulse sometimes coming through me. I read that I might try a new relay board for this kind of problem, here's a picture of mine. Anyone have an extra relay board, or any other ideas of what is wrong and what I might try next!!! I'm stumped. (IMG:style_emoticons/default/screwy.gif)
76-914 |
Jul 28 2016, 06:07 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,502 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Is one of the female spades in the relay board dropping when you try to push the regulator onto it? Push on each one to see if it stays in place or drops. If so get another relay board. (IMG:style_emoticons/default/beerchug.gif)
oakdalecurtis |
Jul 28 2016, 06:17 PM
Is one of the female spades in the relay board dropping when you try to push the regulator onto it? Push on each one to see if it stays in place or drops. If so get another relay board. (IMG:style_emoticons/default/beerchug.gif) i will remove the relay board and see if the contacts are holding, thanks |
oakdalecurtis |
Jul 28 2016, 06:30 PM
Is one of the female spades in the relay board dropping when you try to push the regulator onto it? Push on each one to see if it stays in place or drops. If so get another relay board. (IMG:style_emoticons/default/beerchug.gif) i will remove the relay board and see if the contacts are holding, thanks Removed relay board, you were right, female spades in board were pushing out. Does the bottom of my relay board look normal? Looks like it's opened up and melted somewhat on the edges? Is that the way it should look??? (IMG:style_emoticons/default/WTF.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 05:41 AM |
