Brake light indicator |
TroyVB |
Jul 29 2016, 02:13 PM
Newbie Group: Members Posts: 17 Joined: 21-July 16 From: Northwest IA Member No.: 20,214 Region Association: None |
I am working on electrical issues. My brake light indicator seems to be trying to run the flasher relay. I have checked the handbrake switch and it works the way it should with the fasten seatbelt indicator. Does that switch also light the brake indicator light? I am also not sure if I have the correct fuel guage.
I seem to have all the other lights working correctly now. Thanks for the help. TVB |
zambezi |
Jul 29 2016, 02:59 PM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
Low brake pressure sensor makes the warning light flash. The hand brake will make the light illuminate steady. The pressure sensor is on the master cylinder and has a reset button that pops out of the center of the switch when a pressure loss is detected. Push it back in and it will reset.
TroyVB |
Jul 29 2016, 04:15 PM
Is this the switch at the base of the brake pedal or is it accessed somewhere else? Can't seem to find a reset button on the switch on the floors
May have found what you are talking about on the side of the master cylinder underneath the car. PO has the switch gooped with silicone can I test by connecting those wires together? |
Lo-Fi Version | Time is now: 17th May 2024 - 06:07 PM |
