WTB '6' or 911 oil pipe, Tubing part to make repair |
rgalla9146 |
Aug 4 2016, 10:52 AM
Advanced Member Group: Members Posts: 4,560 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
I need a 3 inch section of tubing from an oil plumbing system.
The nipple I need must be steel and must be straight, not curved The most likely used source would be from a later 911 system. Takes a 36mm nut Please see picture. Used is fine, but not too rusty or pitted. TIA Rory Don't need the nut. .....gees the pichers are uge. Attached thumbnail(s) |
worn |
Aug 4 2016, 06:23 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I need a 3 inch section of tubing from an oil plumbing system. The nipple I need must be steel and must be straight, not curved The most likely used source would be from a later 911 system. Takes a 36mm nut Please see picture. Used is fine, but not too rusty or pitted. TIA Rory Don't need the nut. .....gees the pichers are uge. Might have it. Warren |
Lo-Fi Version | Time is now: 24th May 2024 - 06:22 PM |
