Steel Gt rocker flares |
gms |
Aug 6 2016, 08:00 AM
Advanced Member Group: Members Posts: 2,694 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
nice work Ben!
Mark Henry |
Aug 6 2016, 08:20 AM
I just want the ends, I will weld them on to my own original steel rockers. This would be the best way to do this, sell the ends separately so the builder can custom align them to fit their flairs. BTW Restoration design makes new stock outer rockers, would be an easy job to weld these on for a perfect GT rocker. |
Aug 6 2016, 11:11 AM
I just want the ends, I will weld them on to my own original steel rockers. This would be the best way to do this, sell the ends separately so the builder can custom align them to fit their flairs. BTW Restoration design makes new stock outer rockers, would be an easy job to weld these on for a perfect GT rocker. Yes, I have 2 sets of them. They will make a great base for the flared ends. So much more durable than fiberglass. |
dakotaewing |
Aug 6 2016, 01:15 PM
Senior Member Group: Members Posts: 1,160 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region |
Hey Ben,
Good to see you found the world. I'd be interested in a set of the ends as shown, pending price. Send me a PM here or on Instagram once you determine price - Thanks, Thom Ewing |
mb911 |
Aug 6 2016, 02:44 PM
914 Guru Group: Members Posts: 6,811 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
A couple of questions to answer. Yes I teach welding and fabrication at a local college. I teach how to properly use cnc brake presses,planishing hammers, English wheels, slip rollers, plate rollers, standard box and pan brakes, shot bags, shrinking and stretching metals.. I have done this for 16 years. Previous I was a welder fabricator in the avaitiob world along with rotax trained to rebuild all of their aviation engine types. Rebuilt 100s of them over the years. Along with that I had my Porsche only business where I designed and built all of the m&k exhaust.. So I guess metal working and engine builds have always been part of my life..
Now to these parts to be honest they take enough time to make that it maybe to costly to retail. I am not sure though. I would say that materials are probably only about 8 dollars per corner with the steel, blending disks, filler metals and argon. That said I believe labor is going to be about 1-1 1/2 hours per corner to make. So price might get up there. Maybe a group but and have laser cuts done Would be the best way to do this? That would help drive the price down |
dakotaewing |
Aug 6 2016, 05:04 PM
A couple of questions to answer. Yes I teach welding and fabrication at a local college. I teach how to properly use cnc brake presses,planishing hammers, English wheels, slip rollers, plate rollers, standard box and pan brakes, shot bags, shrinking and stretching metals.. I have done this for 16 years. Previous I was a welder fabricator in the avaitiob world along with rotax trained to rebuild all of their aviation engine types. Rebuilt 100s of them over the years. Along with that I had my Porsche only business where I designed and built all of the m&k exhaust.. So I guess metal working and engine builds have always been part of my life.. Now to these parts to be honest they take enough time to make that it maybe to costly to retail. I am not sure though. I would say that materials are probably only about 8 dollars per corner with the steel, blending disks, filler metals and argon. That said I believe labor is going to be about 1-1 1/2 hours per corner to make. So price might get up there. Maybe a group but and have laser cuts done Would be the best way to do this? That would help drive the price down Most of the guys here that would want these will have some welding skills. You could offer the cnc'd cut parts, as one option, and welded as another. Cost difference would be the cost of your labor. Each corner would need to be labeled if you simply sold the steel - Again, just my .02 - |
mb911 |
Aug 6 2016, 05:13 PM
A couple of questions to answer. Yes I teach welding and fabrication at a local college. I teach how to properly use cnc brake presses,planishing hammers, English wheels, slip rollers, plate rollers, standard box and pan brakes, shot bags, shrinking and stretching metals.. I have done this for 16 years. Previous I was a welder fabricator in the avaitiob world along with rotax trained to rebuild all of their aviation engine types. Rebuilt 100s of them over the years. Along with that I had my Porsche only business where I designed and built all of the m&k exhaust.. So I guess metal working and engine builds have always been part of my life.. Now to these parts to be honest they take enough time to make that it maybe to costly to retail. I am not sure though. I would say that materials are probably only about 8 dollars per corner with the steel, blending disks, filler metals and argon. That said I believe labor is going to be about 1-1 1/2 hours per corner to make. So price might get up there. Maybe a group but and have laser cuts done Would be the best way to do this? That would help drive the price down Most of the guys here that would want these will have some welding skills. You could offer the cnc'd cut parts, as one option, and welded as another. Cost difference would be the cost of your labor. Each corner would need to be labeled if you simply sold the steel - Again, just my .02 - The problem is that there is extensive forming that needs to be done and probably not by the novice. I have been doing this along time and it is not for the weekend warrior. |
Aug 6 2016, 05:37 PM
Ben. Exactly what I've been looking for. I'm in for two sets. I don't need them right away but I want them. We'll work out the details. Thanks.
porbmw |
Aug 6 2016, 08:52 PM
Senior Member Group: Members Posts: 811 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None |
Really dumb question
What did the factory do re their GT cars??? Did they fabricate steel...or use fiberglass, for weight and other issues? |
Aug 6 2016, 09:12 PM
dadaDaveed |
Aug 7 2016, 11:10 AM
Member Group: Members Posts: 111 Joined: 19-February 09 From: San Antonio, TX Member No.: 10,071 Region Association: Southwest Region |
Put me down for a set!
mb911 |
Aug 9 2016, 02:02 PM
jkb944t |
Aug 9 2016, 02:35 PM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
I would be interested in a set of them if you proceed with them.
Jeff B |
mb911 |
Aug 9 2016, 02:39 PM
I am going to make sets for everyone that wants a set. I will probably do a group but type of system with a deposit to make them and a final payment when they are done. Should be able to come up with a price by the end of the week.
mb911 |
Aug 9 2016, 02:48 PM
ben*james |
Aug 9 2016, 09:18 PM
LIFER Group: Members Posts: 511 Joined: 16-February 09 From: Portland Oregon Member No.: 10,062 Region Association: Pacific Northwest |
Well, I'm a dreamer and I dream of having GT flares. Glad you are making this product!
ahycaramba |
Aug 10 2016, 02:32 AM
“I live my life a quarter mile at a time.” Group: Members Posts: 161 Joined: 17-March 15 From: Murrieta, California Member No.: 18,534 Region Association: Southern California |
I was not happy about selling my nice set of steel rocker panels for fiber glass GT set up. This is a much more diserable alternative. Please count me in for one set.
Thanks Al |
Beach914 |
Aug 10 2016, 07:37 AM
Senior Member Group: Members Posts: 962 Joined: 28-March 10 From: Aliso Viejo Member No.: 11,519 Region Association: Southern California |
I'm in for a set for my 70 GT
rudedude |
Aug 10 2016, 08:52 AM
Senior Member Group: Members Posts: 508 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest |
I'd take a set for my next project
eric914 |
Aug 10 2016, 09:36 AM
Member Group: Members Posts: 381 Joined: 28-January 04 From: Waynesville OH Member No.: 1,613 Region Association: Upper MidWest |
I'm in for a set as well.
Lo-Fi Version | Time is now: 25th April 2024 - 06:50 PM |
