front height question, is this ok? PIC |
opera guy |
Apr 12 2005, 12:39 PM
Member Group: Members Posts: 337 Joined: 28-June 04 From: upland, ca Member No.: 2,268 |
geez joe, take it easy on that "F5" (refresh) button wud'ya (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif)
Joe Ricard |
Apr 12 2005, 12:40 PM
Passenger side looks lower than drivers. What does the measuring tape tell you?
opera guy |
Apr 12 2005, 12:41 PM
i think its the camera angle... even if they are pointing down, its very slightly |
Joe Ricard |
Apr 12 2005, 12:42 PM
ya I suppose I should be working. Sorry fast connection |
opera guy |
Apr 12 2005, 12:43 PM
measuring tape?!?!?! you have to use measuring tape? you mean, they both gotta be same height? hehehe didnt use a measuring tape, i will later... anyway, after my fat ass is in the car, the driver side is gonna be lower anyway (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif) |
Joe Ricard |
Apr 12 2005, 12:49 PM
I think Mr. Atkins can fix that problem for ya. (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif) Sorry I really need to get some work done. But this is just way more fun than writing design specs.
AndyC |
Apr 12 2005, 12:51 PM
Bend over and empty your wallet Group: Members Posts: 134 Joined: 14-January 05 From: Rugby,UK Member No.: 3,445 |
I say lower - I can still see your tyres, you will never wear out the paint under your fenders at that height (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif)
rhodyguy |
Apr 12 2005, 05:48 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
in the pass side shot it appears that the tie rod outer end is angled up a bit. the drivers side "looks" like it's fairly close to being parallel to the horison. the rod and arm "look" close. save up the coin for the corner balanceand alignment. your weight will (should) be factored in. how does the whole backspacing, offset compare with your rims and 4 lug fuch? low slung looks cool, i mean on cars joe (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif). my car was raised a bit, even with a bump steer kit installed, to achieve the angularity the tech and i talked about. use of car played a big part. i run 205/50 tires. they make my car look higher than it is, but they fit in the wheelwells nicely and 0 rub. your car looks tall in the ass. how does it corner. if you approach a set of rail road tracks perpendicular, does the sterring wheel dance when you cross the rails?
k |
Lo-Fi Version | Time is now: 31st May 2024 - 08:02 PM |
