ignition wire on starter, where to put it? |
echocanyons |
Apr 12 2005, 01:20 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
On the solenoid on my starter there are two sets of spade connectors.
One closest to the starter, in between the power cable and one on the outer side of the solenoid further away from the starter, on the other side of the power wire. Where should I connect the yellow igntion wire? I would try them both but I'm afraid Ill fry my new harness. I have a battery cable and a power cable attaced to the same area and the yellow spade wire Am I missing anything? |
SGB |
Apr 12 2005, 01:37 PM
I connected mine on the spade further away from the starter moter. I read (can't remember where- pelican maybe... reliable source I know) that they are both to the same pole on the solinoid, just two alternate locations depending on need.
Joe Ricard |
Apr 12 2005, 01:57 PM
Both terminal spades are electrically connected. So either one is fine.
echocanyons |
Apr 12 2005, 01:58 PM
fatlando |
Apr 12 2005, 02:15 PM
Member Group: Members Posts: 259 Joined: 6-September 04 From: imperial beach, california Member No.: 2,700 |
Try this.
I was in the same boat as you. I fried my last starter until i got the photo from the board. Attached image(s) |
Lo-Fi Version | Time is now: 16th May 2024 - 10:16 AM |
