Garage Find 1972 East Coast |
lvnzdrm |
Aug 12 2016, 12:21 AM
Member Group: Members Posts: 126 Joined: 30-January 13 From: Virginia Member No.: 15,452 Region Association: MidAtlantic Region |
I met a guy at a local Air Cooled VW Club meeting a few years back. He was an older guy who said he had a 914 in his garage and had never drove it. He asked for my contact info and if I ever worked on them. 2 years later I get a call from him asking if I could come look at the car. I grabbed a buddy and we headed over. When we arrived we saw several cars under tarps and I thought this thing was going to need a lot of work being an East Coast car. We we to a garage out back and there it was.... A 1972 local owned, zero rust car. He bought it from an estate sale 8 years ago. After chatting a bit I discovered he wanted to sell the car. After a little negotiating with house CEO and the pending Sale of my Mini S, I now own another 914. It felt like something out of American Pickers and I'm honored to have been able to buy this car. It has a re-spray but is very original with owners manual and tool pouch. I hope to bond with it this weekend and get it going. Any feedback or comments are appreciated.
Jon Attached thumbnail(s) |
lvnzdrm |
Aug 28 2016, 06:12 PM
I'm new to the FI system... The car starts and idles at 3K rpm, after it warms up the idle comes down and it starts to surge. As the engine gets warmer it will slowly start to die then surge back up. The RPM goes to 3k then drops back down...The engine also gets very hot.... And pops and pings after I shut it off. Any thoughts on where to begin? Thanks in advance for the help.
BeatNavy |
Aug 28 2016, 06:42 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
I'm new to the FI system... The car starts and idles at 3K rpm, after it warms up the idle comes down and it starts to surge. As the engine gets warmer it will slowly start to die then surge back up. The RPM goes to 3k then drops back down...The engine also gets very hot.... And pops and pings after I shut it off. Any thoughts on where to begin? Thanks in advance for the help. Jon, I'm going to give you the obligatory link: http://members.rennlist.com/pbanders/djetparts.htm And specific to idle: http://members.rennlist.com/pbanders/idle.htm If you're going to do your own work, you definitely need to learn about D-Jet, and that's about the best resource there is. You can figure it out, but there's a little bit of a learning curve particularly as you try to make up for years of maintenance that may or may not have been done. I like D-Jet personally, but there are a lot of variables in play, and if they haven't been serviced recently they're all suspect at some point. My first guess would be that you're running lean, but that's just a guess at this point. You need to eliminate vacuum leaks and do some basic maintenance. I'd replace all the vacuum lines and perhaps have the injectors serviced. Then start looking to adjust valves and do the basic tune-up items (plugs, points, timing, fuel pressure, etc.). |
Lo-Fi Version | Time is now: 25th May 2024 - 09:01 PM |
