wheel bearing spacer when using 911 halfshafts |
buck toenges |
Apr 13 2005, 10:36 AM
Senior Member Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None |
I put in a really cool 4 speed 901 tranny that has a sportomatic pinion set and a lsd . It came with 911 half shafts and the big cv joints. The problem is I need a set of spacers for the bearings(?) so the nut doesn't bottom out and the hubs don't shimmy. Anybody got a source or part number for these spacers?
(IMG:http://www.914world.com/bbs2/html/emoticons/wavey.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/wavey.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/wavey.gif) |
Brad Roberts |
Apr 13 2005, 01:31 PM
OK. Let me see if I have this straight:
Early 911 4 bolt 2 pin CV joint through a early 911 5 lug hub (that fits our stock 914 wheel bearing ?? Is the above statement true ? The stub axle the large CV uses fits the 911 hub without a spacer. I'm not quite sure what your issue is. It should all tighten up without issue. I use these same stub axles/drive flanges/axle assemblies in several race cars with 915's in them. It all bolts together without a spacer. What does need a spacer: late 911 SC rear drive flanges in our stock 914 wheel bearing. B |
davep |
Apr 13 2005, 02:13 PM
Would you not need a spacer on the tranny output flange since the 911 shafts are shorter?
Brad Roberts |
Apr 13 2005, 06:21 PM
We are up to 3 complete race seasons on rebuilt axles with no spacers. I used to spend the money.. then I realized that they are only .500 shorter. Split this between two CV's and they easily handle .250 apiece. I check them every time we pull the tranny. No signs of "scary" wear. 325hp 3.2 with a 915 and 12 inch wide slicks and Guard limited slip. I also found that Porsche had some output flanges that where different "lengths". Some of that .500 can be taken up with wider tranny output flanges.
B |
buck toenges |
Apr 14 2005, 11:51 AM
Here is where I am at. I have a 901 tranny with the big output flanges using 6 10mm bolts. I need to get everything from the tranny out put flanges to 5 bolt hubs that have a bigger diameter where the stub axel fits into the hub. I can substitue those hubs with the smaller 914 hubs I have with the 5 bolt pattern if I need to. So what do you guys suggest and where can I get them? I am using a 3.2 and built up 4 speed 901 tranny.
Thanks, and may the force be with you...... My kids are starting to drive me nuts with their star wars fever. Buck |
andys |
Apr 14 2005, 02:54 PM
Brad, How much of a spacer, and are they available? I measured a difference of 2mm betwwen the early and late bearings. Andy |
Lo-Fi Version | Time is now: 16th May 2024 - 06:09 AM |
