Fuel Lines, Where do I get them? |
jarbuthnot |
Apr 13 2005, 04:00 PM
Senior Woman Driver Group: Members Posts: 201 Joined: 22-August 03 From: Pembroke, ME Member No.: 1,065 |
While the car was in the parked this winter, the garage smelled of gas. Now that I've driven it again, there is a slight smell inside, but much stronger outside the car. My mechanic has taken the gas tank out and said the fuel lines to it seem ok, but he can't easily check the ones that go through "the tunnel" (his words). The feed and return lines are currently clear plastic.
Should I just replace them? If so, with what? While the tank is out, he can attach new lines to the old ones and pull the new ones through. (again his words). Where do I buy gas lines? What kind should I get? He has 'steel tubing' he could use, but should it be something different? |
v82go |
Apr 13 2005, 04:09 PM
Resident Contrarian Group: Members Posts: 249 Joined: 9-December 04 From: Lakeland, Fl. Member No.: 3,250 |
Steel tubing will work fine. I used steel brake line when I did mine (no problems)
Bob |
Grimstead |
Cheaky Monkey Group: Members Posts: 835 Joined: 20-March 05 From: Corona, Ca Member No.: 3,789 Region Association: Southern California |
Try here....
Replacement 914 fuel lines |
TravisNeff |
Apr 13 2005, 05:01 PM
I hear that you can also get replacement lines from your local dealer. They've worked for the past 30 years.. That said, my last replacement was with steel brake line - I'll have to replace the orignals on the new car pretty soon, I may just get the plastic lines - unless they are horribly expensive. If so, I'll do steel for CSOBSC spite.
jarbuthnot |
Apr 13 2005, 07:03 PM
Unfortunately, my local dealer is four hours away (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) . So, I'll tell my mechanic to go with the steel tubes he already has. Thanks for the advice. You guys are great as always (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
Lo-Fi Version | Time is now: 16th May 2024 - 03:55 PM |
