What do you do for the throttle cable on a suby swap? |
tazz9924 |
Aug 19 2016, 02:55 PM
Senior Member Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
as the title says how do u connect a throttle cable to the suby engine?
Mike Bellis |
Aug 19 2016, 06:23 PM
Connect it to the throttle body... (IMG:style_emoticons/default/biggrin.gif)
Not sure about a Subie but I had to make a custom cable for all of my conversions except the latest one. There is no throttle cable on my Audi conversion... |
A&P Mech |
Aug 19 2016, 07:30 PM
Member Group: Members Posts: 401 Joined: 10-September 13 From: United States Member No.: 16,371 Region Association: Rocky Mountains |
partwerks |
Aug 19 2016, 07:51 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
I think mine had a barrel nut holding the end, if that is what you are referring to?
76-914 |
Aug 20 2016, 11:03 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,500 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I like A&P's, God damned show off. (IMG:style_emoticons/default/biggrin.gif) Terry Cable (800-854-4691) will make you one. Ask for Able. It's a longer 914 cable. The cable is about 3-4" longer while the sheath remains stock, IIRC. Do this; place your stock cable as it will be in use then measure how short it is. They will ship it with a barrel nut. Order it a little on the long side. You can trim off the extra.
I saw another approach (maybe ChrisH's) where the stock Suby cable was used on the TB side then attached to the stock cable via a swedgelock fitting. |
A&P Mech |
Aug 21 2016, 03:39 PM
I like A&P's, God damned show off. (IMG:style_emoticons/default/biggrin.gif) Terry Cable (800-854-4691) will make you one. Ask for Able. It's a longer 914 cable. The cable is about 3-4" longer while the sheath remains stock, IIRC. Do this; place your stock cable as it will be in use then measure how short it is. They will ship it with a barrel nut. Order it a little on the long side. You can trim off the extra. I saw another approach (maybe ChrisH's) where the stock Suby cable was used on the TB side then attached to the stock cable via a swedgelock fitting. Kent, someone one here has heat and AC in his conversion. I think he might be my hero and a bigger show off! (IMG:style_emoticons/default/biggrin.gif) So why aren't you and Chris H coming to the RRC? We sure could use a few more outlaws. (IMG:style_emoticons/default/aktion035.gif) |
Lo-Fi Version | Time is now: 14th May 2024 - 05:33 PM |
