QUOTE(76-914 @ Aug 20 2016, 11:03 AM)
I like A&P's, God damned show off.
Terry Cable (800-854-4691) will make you one. Ask for Able. It's a longer 914 cable. The cable is about 3-4" longer while the sheath remains stock, IIRC. Do this; place your stock cable as it will be in use then measure how short it is. They will ship it with a barrel nut. Order it a little on the long side. You can trim off the extra.
I saw another approach (maybe ChrisH's) where the stock Suby cable was used on the TB side then attached to the stock cable via a swedgelock fitting.
Kent, someone one here has heat and AC in his conversion. I think he might be my hero and a bigger show off!
So why aren't you and Chris H coming to the RRC? We sure could use a few more outlaws.
