5 lug Fuchs under stock fenders. |
daytona |
Aug 20 2016, 02:00 PM
daytona Group: Members Posts: 435 Joined: 13-April 14 From: Ormond Beach, Florida Member No.: 17,249 Region Association: South East States |
Hi guys,
I have a set of four 5 lug fuchs. These are the all fronts from a 944 Turbo. The wheels are 16x7. The reason I got these wheels is because I was told that they fit under the stock fenders on my 1974 914. Can anyone tell me what are the largest tires that I can fit on these wheels and still maintain the stock fenders? Thanks, Bill. |
messix |
Aug 20 2016, 02:17 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
depending on how Hans and Gunter built the car that day anything from a 205 to a 225
brant |
Aug 20 2016, 03:48 PM
Your not going to get a 225 anything under an actually stock fender
Maybe heavily rolled. Maybe |
Chris914n6 |
Aug 20 2016, 06:12 PM
Jackstands are my life. Group: Members Posts: 3,318 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
boxstr |
Aug 20 2016, 06:43 PM
I have run 205/45/16 under stock fenders.
Craig at CAMP |
Aug 20 2016, 07:07 PM
914-6 GT in waiting Group: Members Posts: 19,269 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Depending on the car, those wheels might not fit at all.
colingreene |
Aug 20 2016, 07:13 PM
Senior Member Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
I dunno if it would fit, i bought 6's because i did not want to move metal on my car thats very straight.
I figured if i wanted bigger wheels i would suck it up and flare it. Honestly a 6 with good tyres and a well set up spension should have plenty of grip. |
sixnotfour |
Aug 20 2016, 09:55 PM
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
all fuchs 16 x 7s have the same offset 911 /951 ...951 have brake cali clearance
JRust |
Aug 20 2016, 10:29 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
all fuchs 16 x 7s have the same offset 911 /951 ...951 have brake cali clearance (IMG:style_emoticons/default/agree.gif) Jeff know's his Fuchs. Rolled fenders in the rear for sure. Fronts will be no problem. I'd say better luck with a lower profile like the 205/45 craig mentioned. I did run 215/40/16's on all for corners with no problems but my rear lips were rolled |
messix |
Aug 20 2016, 11:05 PM
jeff how big did you go on 7"s
sixnotfour |
Aug 20 2016, 11:11 PM
225/50 roll em (IMG:style_emoticons/default/smoke.gif)
daytona |
Aug 21 2016, 06:21 AM
Thanks guys,
That is a lot of info. I see that most suggest 205s. I didn't think that you could fit 205s on a 7" wide rim. So it seems that 205s for sure, 215s maybe, and 225s yes but I will need to roll the lips on the rear fenders. Do I have it right? Thanks for the responses. Bill. |
Aug 21 2016, 06:34 AM
205's on 16x7 is not "for sure" on the back. But if you want to think that, go ahead and buy the tires. (IMG:style_emoticons/default/smile.gif)
225 is more than rolling the lip. It's heavily massaging the whole fender. |
brant |
Aug 21 2016, 07:29 AM
I think that you should run 6 inch wide wheels of f you want a guaranteed fitment.
I've converted 3 cars to 5 bolt suspension You might get 7's? Not a guarantee |
Spoke |
Aug 21 2016, 08:27 AM
7x16 Fuchs on the rear with 225/50/16. Had to pull the fenders out to make it fit. Wheels and tires look awesome now.
boxstr |
Aug 21 2016, 09:06 AM
The 205/45/16 tires that I used on the 7" Fuchs were Dunlop sport tires, I was able to find complete dimensions for these tires and determined before purchase if they would work. And they did. Please note, the clearance can be very different from one side to the other side. This is just inherent in the 914, manufacturing was not laser precise on the rear suspension. After mounted you may find that one side has lots of clearance, and you go to the other side and you are lucky to be able to slide a thin dime between tire and fender edge.
Craig at CAMP |
Chris914n6 |
Aug 21 2016, 11:26 AM
Good point above. Tire brand matters, I've seen up to 5/8" difference in width on same 225 designation.
Tirerack.com does a good job listing individual tire specs. |
DRPHIL914 |
Aug 21 2016, 01:08 PM
Mine didn't fit it was too tight, they rubbed and blistered the paint and then making matters worse the attempt to stretch them bent the lips and buckles them- so be careful when stretching them- who helps you do this or how you approach it- I had 6" and the fit perfect, the 7" rims rubbed- but this is not on all cars , some have put in 7's with no mod, you never know until you try.
Attached thumbnail(s) |
DRPHIL914 |
Aug 21 2016, 01:10 PM
So...
rhodyguy |
Aug 21 2016, 01:28 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,079 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Makes for an expensive set of shoes and a major hassle for a tad more tire width.
Lo-Fi Version | Time is now: 14th May 2024 - 01:45 AM |
