Main targa top seal install advice |
carcus |
Aug 21 2016, 01:52 AM
Member Group: Members Posts: 223 Joined: 16-March 16 From: Colorado Springs Member No.: 19,760 Region Association: Rocky Mountains |
Got the most expensive of the targa top seals. The sides of the targa were easy...now got the main one from 914 rubber. This is the U shaped one that goes on top of the windshield frame and to the inner doors. The OEM one I have is so rotted I am going to have to scrape and work it off. Anyone have some tips to doing the install with the new replacement part correct the first time? Should I use some RTV silicone under the rubber gasket? I have replaced all the worn rubber gaskets so far but this one I want to make sure I do not have to buy again if I mess it up. Also after seeing the front trunk channel where the previous owner put the seal on wrong....I am afraid to see what is under the rotted seal. Thanks all!!!
Aug 21 2016, 04:23 AM
914-6 GT in waiting Group: Members Posts: 19,258 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
No rtv!
If there's not already a thread on this site, I'm sure Mikey/Mark can do a quick write up. I'm guessing lubricants will be your friend. |
Mikey914 |
Aug 21 2016, 12:31 PM
The rubber man Group: Members Posts: 12,659 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Do the sides 1st. The take the center and install in th middle working the way out to the ends. It should be tight, but not need anything else to hold it on. If it's a little too tight yo can take a big flat screwdriver and open up about an inch or so to get it started. If you need to lubricate, a little soapy water or glycerin will work.
Cuda911 |
Aug 21 2016, 12:35 PM
Senior Member Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California |
Another tip: Installing that seal was tough on my thumbs trying to press in the top horizontal section. Then I used the side of a fat sharpie to push in the seal, and it worked much better than my thumbs. Lots of dish soap too. I used a small paint brush to keep paint the soap into the seal groove, to keep the mess factor down.
Harpo |
Aug 21 2016, 01:33 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
I gave up and had McMark install mine. It was very humbling how quickly he installed it.
Lo-Fi Version | Time is now: 10th May 2024 - 04:02 AM |
