how to align the steering column/wheel with the rack? |
draganc |
Aug 21 2016, 08:11 PM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
I took the front end out to rebuild it and also took the "lower" part of the steering column off.
Now that everything is rebuild and sparkly, how do a realign the steering wheel with the steering rack? The front suspension, cross member, wheel sect are still off the car. Thanks for the input! |
Catorse |
Aug 21 2016, 08:31 PM
Member Group: Members Posts: 194 Joined: 27-August 15 From: Los Angeles Member No.: 19,106 Region Association: Southwest Region |
Center the steering rack so both tie rod ends are equal. Use a ruler or tape measure; just trying to get close here.
Then, center the steering wheel in the car. Connect the rack to the wheel. Take the car to an alignment shop to adjust the toe in....done |
Aug 21 2016, 08:46 PM
Resident German Group: Admin Posts: 41,628 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Center the steering rack so both tie rod ends are equal. Use a ruler or tape measure; just trying to get close here. Then, center the steering wheel in the car. Connect the rack to the wheel. Take the car to an alignment shop to adjust the toe in....done (IMG:style_emoticons/default/agree.gif) |
draganc |
Aug 21 2016, 09:26 PM
Thanks for the quick and simple answer! (IMG:style_emoticons/default/beerchug.gif)
For whatever reason I was overthinking- or not, the setup. |
Lo-Fi Version | Time is now: 11th May 2024 - 11:53 AM |
