Push the clutch, heard a snap, and then the pedal went to the grounD |
anthony |
Aug 23 2016, 01:23 PM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
I just called a tow truck which is an hour away. Any words of wisdom? Any chance I could fix it before they get here? |
Aug 23 2016, 01:25 PM
Resident German Group: Admin Posts: 41,633 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Clutch tube broke lose either inside the center tunnel or at the rear firewall or both ...
(IMG:style_emoticons/default/sad.gif) |
anthony |
Aug 23 2016, 01:29 PM
Crap! That doesn't sound like a quick fix.
Aug 23 2016, 01:32 PM
Or maybe your clutch cable just snapped. But they rarely do ...
(IMG:style_emoticons/default/idea.gif) |
bretth |
Aug 23 2016, 01:38 PM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
I would have thought the clutch cable snapped or cable pulley let go on the trans but I haven't had enough experience with mine to be sure. If the cable has snapped you may want to look under the car and see if the cable end is still there to see if you can pull it off to keep the end pieces from falling off and getting lost while being towed.
Brett |
falcor75 |
Aug 23 2016, 01:39 PM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
If the cable snapped you probably lost the wedge piece that connects the cable to the throwout bearing arm.
Tom_T |
Aug 23 2016, 01:41 PM
Or maybe your clutch cable just snapped. But they rarely do ... (IMG:style_emoticons/default/idea.gif) They will snap the cable with age &/or if the transaxle's ground strap or lugs are bad connections or missing. Either way, it's not an easy on-the-road fix. Anthony, you can drive your 914 short distances with minimal stops by putting it into 2nd or 3rd gear with the engine off, then start the motor (it will buck until up to speed, & then cruise in that gear until you must stop again (some folks will blip the gas & try to shift up, but that can grind the synchros, so I wouldn't). PS - I'd done that a few times in the decade & 132k miles that mine was my DD, so they do snap clutch cables sometimes, & you can get to a shop if close enough with that start-in-gear technique. When my clutch tube broke loose, it was more a matter of a sloppy & only partially disengaging clutch - rather than complete loss, although mine didn't completely break free & run out the back of the firewall (& it is an in the shop fix for the tube also). If you're close to your shop, then try that, otherwise wait for the tow service, & hopefully you've asked for a flatbed, so that your front valance or spoiler won't get buggered up. Take pix of the car's condition before the tow for your records, in case of any damage by the tow. Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Montreal914 |
Aug 23 2016, 01:54 PM
Senior Member Group: Members Posts: 1,552 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Seems like what I've lived about a year ago.
Cable snapped pulling out of drive way. Replace cable, adjust clutch, good to go (IMG:style_emoticons/default/driving.gif) Might have to readjust the clutch after a few days. Good luck with your repair. |
Andyrew |
Aug 23 2016, 02:04 PM
I've snapped 3 clutch cables. They snap and that is what happens. When the tube breaks loose your clutch will have SOME feel to it but wont do enough.
TheCabinetmaker |
Aug 23 2016, 02:07 PM
Tom nailed it. Drive it home.if you shift at just the right moment it will up shift without grinding. Engage clutch, blip throttle, and shift. I've driven home 5 miles in traffic this way.
tbox56 |
Aug 23 2016, 02:08 PM
Member Group: Members Posts: 54 Joined: 14-November 04 From: Colorado Member No.: 3,115 |
I have had the cable sheath pull out of the holder by the pulley in the back. This had exactly the same symptoms.
If this is it, it's your lucky day, throw a zip tie around it and drive home! Good luck! |
Aug 23 2016, 02:14 PM
When the tube breaks loose your clutch will have SOME feel to it but wont do enough. Nope, not if it comes lose on the rear firewall. Your pedal will go to the floor with no usable clutch. Been there, done that ... (IMG:style_emoticons/default/dry.gif) |
anthony |
Aug 23 2016, 02:15 PM
It looks like the cable frayed and snapped right at the pulley wheel.
TheCabinetmaker |
Aug 23 2016, 03:33 PM
Outstanding
jim_hoyland |
Aug 23 2016, 05:40 PM
Get that VIN ? Group: Members Posts: 9,284 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Put a spare in your front trunk for the next time; also helps to have a couple of tools handy;some bunji cord, latex gloves, flashlight, and any other tools that are needed.
The hardest part can be reaching into the pedal cluster area to change the front attachment point. |
Valy |
Aug 23 2016, 05:47 PM
Senior Member Group: Members Posts: 1,673 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Check your ground strap at the transition. A bad one will cause grounding through the clatch cable and you know how that ends.
BeemerSteve |
Aug 23 2016, 06:28 PM
Member Group: Members Posts: 239 Joined: 2-September 15 From: Van Zandt, Wa Member No.: 19,123 Region Association: Pacific Northwest |
Undeniably clutch tube woes! Happened to me and had to put new metal back on the firewall. Also, tacked back in the front for prosperity purposes,.
BeemerSteve |
Aug 23 2016, 06:31 PM
Undeniably clutch tube woes! Happened to me and had to put new metal back on the firewall. Also, tacked back in the front for prosperity purposes,. Well, bloody hell....maybe I should've read further before I posted. Good that it was the cable!!! (IMG:style_emoticons/default/biggrin.gif) |
rgalla9146 |
Aug 23 2016, 09:08 PM
Advanced Member Group: Members Posts: 4,552 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
The first thing to do when the cable snaps is to crawl under the car and retrieve the loose cable end which has the trunion and the two impossible to find 11mm nuts on it.
Was there boot on there too ? Extra points. Oh, if your shift linkage (and battery) is better than the average 914 you could drive the car across the country, no clutch cable necessary. |
Lo-Fi Version | Time is now: 12th May 2024 - 01:35 PM |
