Push the clutch, heard a snap, and then the pedal went to the grounD |
anthony |
Aug 23 2016, 09:28 PM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
No end boot. I never had one as long as I've had this car. Also, only one 11mm bolt installed back there. Should I add another? Will I find an 11mm at the hardware store?
New clutch cable is now installed. I had no problems threading the cable. Reattaching at the pedal cluster was a big PITA. I "lost" the clip down the tunnel at least 4 or 5 times until I got it. The white pulley was essentially frozen and gummed up with road gunk. That is the point where the cable shredded and snapped. I noticed that the speedo cable doesn't look so hot either. There is always something on a 42 year old car.... |
Krieger |
Aug 23 2016, 10:57 PM
Advanced Member Group: Members Posts: 4,718 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Add a second nut and lock that cable down. I have always had two nuts (IMG:style_emoticons/default/biggrin.gif)
euro911 |
Aug 24 2016, 03:03 AM
Lo-Fi Version | Time is now: 23rd May 2024 - 10:27 AM |
