need spring specs for e-brake, the one that holds the pawl to the gear |
914 RZ-1 |
Aug 24 2016, 08:27 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
I need to know the specs/availability of the spring that hold the pawl to the geared pc. I can pull up on the e-brake, but it doesn't stay in place because the spring that holds the pawl is trashed. I've included the parts diagram, but the spring is not listed.
Anybody know where I can get one? Attached image(s) |
Mikey914 |
Aug 24 2016, 08:43 PM
The rubber man Group: Members Posts: 12,670 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Is this what you are looking for?
http://shop.914rubber.com/Early-E-Brake-sp...m?categoryId=-1 Attached thumbnail(s) |
RAX914 |
Aug 24 2016, 09:15 PM
Member Group: Members Posts: 99 Joined: 20-August 14 From: California Member No.: 17,801 Region Association: None |
I've got a '72 also and have the same problem. From what I could find, it looks like the spring piece we need is attached to the metal rod, part #3 in your diagram.
Reference these threads: http://www.914world.com/bbs2/index.php?sho...=249581&hl= http://www.914world.com/bbs2/index.php?sho...387&hl=pawl |
Mikey914 |
Aug 24 2016, 09:55 PM
If I can get a sample I'd be happy to make these.
RAX914 |
Aug 24 2016, 10:08 PM
I wish I had a complete part to help you, but mine is broken.
Hopefully someone has one that you could look at. The spring piece is welded to the metal rod, within the brake handle, which I've pointed out below. I've searched around but couldn't find a replacement. |
Mikey914 |
Aug 24 2016, 11:33 PM
Do you have a pic of the other part that broke off?
RAX914 |
Aug 24 2016, 11:43 PM
Mark,
The picture above is a complete working part, I found that picture while searching for the same spring the OP of this thread is looking for. In the picture above, the piece the arrow is pointing to, is the part that breaks off. |
914 RZ-1 |
Aug 25 2016, 07:56 PM
I think so. The old spring is really trashed, but it looks similar. Does this attach to the end of the metal piece that RAX 914 posted? |
914 RZ-1 |
Aug 25 2016, 07:59 PM
If I can get a sample I'd be happy to make these. Nevermind; I just looked at your website and saw that you do have the compression spring for the knob on the e-brake, but not the one I'm looking for. The one I need is not listed in the PET at all. Now I understand what you mean about needing a sample. |
914 RZ-1 |
Aug 25 2016, 08:13 PM
I've got a '72 also and have the same problem. From what I could find, it looks like the spring piece we need is attached to the metal rod, part #3 in your diagram. Reference these threads: http://www.914world.com/bbs2/index.php?sho...=249581&hl= http://www.914world.com/bbs2/index.php?sho...387&hl=pawl I think you are right. Looks like we might have to fabricate something, or find a spring that will work. I need to look at a functioning e-brake and see if I can check out the spring. I'll see if I can find one; stay tuned. |
Mikey914 |
Aug 25 2016, 10:21 PM
I think I could fabricate a spring easily enough. The problem is attachment. May just have to make a complete piece.
Lo-Fi Version | Time is now: 20th May 2024 - 12:07 PM |
