Tires for a Fuch 16x7" rim, still very tight with Bridgestone potenza 205/50 - other options that might not be as wide on that rim? |
DRPHIL914 |
Aug 29 2016, 10:06 AM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
id like to have a nice looking tire - I know the tires can vary on width even if the numbers are the same- the Potenza hangs over the rim a good bit- id like more than the thickness of 2 credit cards for clearance so short of risking making a mess of the fenders more than they had been I thought someone here might have had clearance issues with 7" rims might have found a good performance tire that is not quite as wide??
Mueller |
Aug 29 2016, 01:45 PM
195 is narrower and might work.
A 23mm offset rim isn't going to work on a bone stock unmolested fendered car unless you raise the sucker up so the fender is higher than the tire. |
Lo-Fi Version | Time is now: 18th May 2024 - 03:39 PM |
