911 Ignition Switch, What is this hole for ? |
jim_hoyland |
Aug 30 2016, 11:46 AM
Get that VIN ? Group: Members Posts: 9,302 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
The left side of the ignition switch has a threaded hole; what isi it for ?
Attached image(s) |
John |
Sep 2 2016, 01:24 PM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
I fabbed a small sheet metal box when I did my car.
I made my steering column from a 1973 911 part and welded wings on it to match my 1974 Chassis then plated it. My steering column locking mechanism as well as all of the switches work as designed. |
jim_hoyland |
Sep 2 2016, 05:15 PM
I fabbed a small sheet metal box when I did my car. I made my steering column from a 1973 911 part and welded wings on it to match my 1974 Chassis then plated it. My steering column locking mechanism as well as all of the switches work as designed. Really nice professional looking job ! (IMG:style_emoticons/default/smile.gif) Does the steering column use the original shaft ? Are the 911 and 914 shafts splined alike ? If different, what mods are required.... |
mepstein |
Sep 2 2016, 07:21 PM
914-6 GT in waiting Group: Members Posts: 19,276 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I fabbed a small sheet metal box when I did my car. I made my steering column from a 1973 911 part and welded wings on it to match my 1974 Chassis then plated it. My steering column locking mechanism as well as all of the switches work as designed. Really nice professional looking job ! (IMG:style_emoticons/default/smile.gif) Does the steering column use the original shaft ? Are the 911 and 914 shafts splined alike ? If different, what mods are required.... 911 & 914 have the same spline. If you are using a 911 steering shaft it would be best to use a wheel from a 70 or 77, 914. No mods required. The later wheels require a small mod and the fit is ok but not perfect because of a chamfered shaft vs flat. |
Lo-Fi Version | Time is now: 19th May 2024 - 05:52 PM |
