911 Ignition Switch, What is this hole for ? |
jim_hoyland |
Aug 30 2016, 11:46 AM
Get that VIN ? Group: Members Posts: 9,302 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
The left side of the ignition switch has a threaded hole; what isi it for ?
Attached image(s) |
Montreal914 |
Sep 28 2022, 09:57 AM
Senior Member Group: Members Posts: 1,560 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
@sixnotfour
Reviving this interesting simpler option thread. (IMG:style_emoticons/default/smile.gif) 1- Was there a specific reason for using a 75-76 column? Was it because the clam shell is plastic? Would a 75-76 plastic clamshell fit a 73-74 column? 2- What was the requirement for using the 73-74 lock assembly and the 75-76 bezel? Look? 3- You machined an aluminum (or steel?) plate that would be mounted on the backside (?) of the dash supporting the assembly? How is the ignition cylinder held to the aluminum (steel?) plate? 4- The angled ignition housing was cut from the aluminum column casting and the clam shell, how was the clamshell rebuilt with its now cylindrical look? Sorry for all these questions... (IMG:style_emoticons/default/rolleyes.gif) Thanks!! (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 06:43 PM |
