911 Ignition Switch, What is this hole for ? |
jim_hoyland |
Sep 2 2016, 07:46 PM
Get that VIN ? Group: Members Posts: 9,277 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
QUOTE 911 & 914 have the same spline. If you are using a 911 steering shaft it would be best to use a wheel from a 70 or 77, 914. No mods required. The later wheels require a small mod and the fit is ok but not perfect because of a chamfered shaft vs flat. Reason I ask is my car has a Momo adapter, a quick release, and a Prototipo wheel....hmmm Attached image(s) |
sixnotfour |
Sep 3 2016, 05:52 PM
914 Wizard Group: Members Posts: 10,423 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
REDRUM (IMG:style_emoticons/default/driving.gif) 1976 Jim your fog light switch will need to be relocated
stock switch.. zero rewire .. in about am hour or two Attached image(s) |
jim_hoyland |
Sep 3 2016, 08:31 PM
SNF: will the connection going to the stock switch reach the left side switch after install ? Or does the connector require lengthening ?
The fog light switch will move to the right side |
sixnotfour |
Sep 4 2016, 05:07 AM
Jim it reaches,,no problem
sixnotfour |
Sep 4 2016, 05:08 AM
Nutter965 |
Sep 4 2016, 07:10 AM
Member Group: Members Posts: 139 Joined: 17-August 14 From: Uk Northern Ireland Member No.: 17,784 Region Association: None |
Restoration design is now making the dimple for the dash to suit a 911 ignition switch !
jim_hoyland |
Sep 4 2016, 08:06 AM
Restoration design is now making the dimple for the dash to suit a 911 ignition switch ! Yup... Attached image(s) |
sixnotfour |
Sep 4 2016, 08:26 AM
ya But ..... KISS
sixnotfour |
Sep 10 2016, 08:25 AM
(IMG:style_emoticons/default/blink.gif) done.. 4-1/8 holes ,, 1- 13\8 hole
Montreal914 |
Sep 28 2022, 09:57 AM
Senior Member Group: Members Posts: 1,545 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
@sixnotfour
Reviving this interesting simpler option thread. (IMG:style_emoticons/default/smile.gif) 1- Was there a specific reason for using a 75-76 column? Was it because the clam shell is plastic? Would a 75-76 plastic clamshell fit a 73-74 column? 2- What was the requirement for using the 73-74 lock assembly and the 75-76 bezel? Look? 3- You machined an aluminum (or steel?) plate that would be mounted on the backside (?) of the dash supporting the assembly? How is the ignition cylinder held to the aluminum (steel?) plate? 4- The angled ignition housing was cut from the aluminum column casting and the clam shell, how was the clamshell rebuilt with its now cylindrical look? Sorry for all these questions... (IMG:style_emoticons/default/rolleyes.gif) Thanks!! (IMG:style_emoticons/default/beerchug.gif) |
sixnotfour |
Oct 2 2022, 05:53 PM
@sixnotfour Reviving this interesting simpler option thread. (IMG:style_emoticons/default/smile.gif) 1- Was there a specific reason for using a 75-76 column? Was it because the clam shell is plastic? Would a 75-76 plastic clamshell fit a 73-74 column? 2- What was the requirement for using the 73-74 lock assembly and the 75-76 bezel? Look? 3- You machined an aluminum (or steel?) plate that would be mounted on the backside (?) of the dash supporting the assembly? How is the ignition cylinder held to the aluminum (steel?) plate? 4- The angled ignition housing was cut from the aluminum column casting and the clam shell, how was the clamshell rebuilt with its now cylindrical look? Sorry for all these questions... :rolleye14 is a 76 Thanks!! (IMG:style_emoticons/default/beerchug.gif) My 914 is a 76.. earlier columns can be done the same way.. I have a mold for a resin piece and one screw holds it in place. Epoxied in a filler piece. |
jim_hoyland |
Oct 3 2022, 06:33 PM
Mine works great; (IMG:style_emoticons/default/smile.gif) And fog light switch is just to the right of the steering column. The blue button is a Start switch.
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 8th May 2024 - 06:18 PM |
