2,2T, Is this a good choice |
DavidSweden |
Aug 30 2016, 02:53 PM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
I have the chance to buy a 2,2T motor.
Is this a good motor for a 914 6 conversion? Its not cheap so I want to be sure that its not wasted money. There is also a 2,4 available and its a bit cheaper. Advice required (IMG:http://www.914world.com/bbs2/uploads_offsite/i1300.photobucket.com-17452-1472590389.1.jpg) |
Dave_Darling |
Aug 30 2016, 03:27 PM
914 Idiot Group: Members Posts: 14,985 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Are you rebuilding either one? If so, then you can change around a lot of stuff and get the driving characteristics you want. If not, then realize that the "T"-spec motor is the lowest-spec one. It makes the least power, but in some ways is more drivable in day-to-day situations.
Larger displacement means the potential for more power. It's not a lot larger between the 2.2 and 2.4 engines, though. Both will have the flywheel attachment that allows you to use the 1969 911 flywheel and 901-based clutch which will hook up to the 914's transmission. Both will be expensive to rebuild, if they need it. I am hearing that parts prices start at $10K for a decent rebuild, and can go up from there. And that's not counting labor or machine shop work. Either one should make for a fun car. Both will put you out of the more-stock racing classes, if that is your eventual intent. Both will sound awesome in a 914, and both will motivate the car pretty well. --DD |
Lo-Fi Version | Time is now: 14th May 2024 - 04:31 AM |
