2,2T, Is this a good choice |
DavidSweden |
Aug 30 2016, 02:53 PM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
I have the chance to buy a 2,2T motor.
Is this a good motor for a 914 6 conversion? Its not cheap so I want to be sure that its not wasted money. There is also a 2,4 available and its a bit cheaper. Advice required (IMG:http://www.914world.com/bbs2/uploads_offsite/i1300.photobucket.com-17452-1472590389.1.jpg) |
horizontally-opposed |
Aug 31 2016, 12:53 PM
Advanced Member Group: Members Posts: 3,431 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
Running a 2.2 and disagree about the torque. 2.0Ts make really nice torque, as do 2.2 and, especially, 2.4Ts. Of course a 3.0 or 3.2 makes more torque, but those can be built into horsepower-oriented engines, too.
My 2.2 has a E pistons with a little compression, a bit of head work, and Solex cams. It really sings through the rev range on the way up to 7200 rpm, but it makes more midrange torque than I expected. A lot more. Very tractable, but does lose steam up top—so it isn't as thrilling at the top as an S. We lost 20 hp with the factory airbox back on (dropping from 169 rwhp to 149), but gained 12 back when we pulled the snorkel and air cleaner off—so need to figure that out as I'd like to avoid rain hats. |
porschetub |
Sep 1 2016, 10:09 PM
Advanced Member Group: Members Posts: 4,698 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Running a 2.2 and disagree about the torque. 2.0Ts make really nice torque, as do 2.2 and, especially, 2.4Ts. Of course a 3.0 or 3.2 makes more torque, but those can be built into horsepower-oriented engines, too. My 2.2 has a E pistons with a little compression, a bit of head work, and Solex cams. It really sings through the rev range on the way up to 7200 rpm, but it makes more midrange torque than I expected. A lot more. Very tractable, but does lose steam up top—so it isn't as thrilling at the top as an S. We lost 20 hp with the factory airbox back on (dropping from 169 rwhp to 149), but gained 12 back when we pulled the snorkel and air cleaner off—so need to figure that out as I'd like to avoid rain hats. (IMG:style_emoticons/default/agree.gif) that's why Porsche did the T motor,a touring drivers car,short stroke motors seems to be popular builds these days,Henry @ Supertechs been doing a few. From a conversion point of view I would suggest the Op goes for the 2.4 easy fit to the 914 g/box and no cooler install. Op has gone into hiding ? hopefully is reading up and makes a wise call (IMG:style_emoticons/default/beer.gif) |
DavidSweden |
Sep 2 2016, 10:15 AM
Thanks for all the input. I decided not to buy the 2.2 or the 2.4 there was something about the seller that didn't quite ring true, the motors were not in Sweden and it was a case of buying without seeing. I feared that both motors require a rebuilt and that could have been potentially too much for my pocket.
However I got hold of a 2.2T motor which is in good shape and its local so I got to see it before commuting myself. It wasn't cheap but it seems like the price of these motors just keeps rising so I figured that if I didn't invest now I would never be able to afford it. I will post some pictures soon I do not have any idea what is required to mate the motor to the 914 g/box, install it in the car or how to set up the oil system All guidance & advice appreciated |
Lo-Fi Version | Time is now: 14th May 2024 - 10:45 AM |
