Got a bit of the shakes, In the front end. |
Mark Henry |
Jun 23 2003, 04:46 AM
I drove to the Niagara Falls VW show yesterday, good run 5 hrs driving time. Average speed of 80 to 90 mph, at 75mph the steering wheel starts to shake a bit. Not too bad, but I want to fix it sooner than later.
I haven't really looked under the car yet, but I've done the push/pull test on the front wheels and both "feel" like they have loose bearings. I tried to tighten one bearing once before but it wasn't the bearing and I have no bearing noise. (IMG:style_emoticons/default/unsure.gif) Any thoughts, tips or things to look for before I dive in? Thanks Mark. P.S. I was the only 914 at the show, I had several 914 rustoration guys drooling all over my Porsche. Good show and a beauty day. (IMG:style_emoticons/default/cool_shades.gif) |
Bruce Allert |
Jun 23 2003, 07:45 AM
Hellions asleep Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
Mark, I "had" the same thing right down to the push pull test... same same.
Went to a tire shop (3rd one) and asked them to balance the tires. There was a very knowledgeable asst. mgr. there that knew about static and dynamic balancing. I havn't had a vibration since. He was at the Americas Tire Store. Here's a pic of the balancing. Top is static and bottom is dynamic. a=b.. c is gud! bruce Attached image(s) |
Mark Henry |
Jun 24 2003, 04:57 PM
Well I have got it figured out.
Anyone want to hazard a guess? I could make a contest out of it. As above, I get a front vibration (steering wheel shake) above 75mph, the loose bearings were not the problem and I have adjusted them. Also the steering wheel was a bit cocked to one side, I didn't think that was part of the problem but turns out that it was. HINTS: In the ol' hot/cold game Bruce was getting warmer but it still was not the real reason. Also I have fixed the problem temporarily, but I will still have to fix it proper. So what do you think the problem was? And what was my temporary fix? (IMG:style_emoticons/default/icon14.gif) Shut up Bradhole! |
Bruce Allert |
Jun 24 2003, 09:46 PM
Did you happen to lose a bolt from a control arm? I scared my self when I looked under the car and one was missing where it attaches to the body. After putting another bolt in the shakes were less but not completely gone. I also had 10 year old tires. They were brand new with lots of tread but still old and "out of round" from sitting so long in storage.
bruce |
ChrisReale |
Jun 24 2003, 09:53 PM
I guess that the lug bolts were loose..did I win?
Andyrew |
Jun 25 2003, 12:03 AM
Hmm I know!! Jacks!! You put it on jacks!
Mark Henry |
Jun 25 2003, 04:55 AM
Bruce, you are so warm!
But which answer was the warm one? LOL (IMG:style_emoticons/default/pain30.gif) |
Drums66 |
Jun 25 2003, 09:05 AM
a new set of tires can do wonder's (IMG:style_emoticons/default/smilie_pokal.gif)
madd_dogg_914 |
Jun 25 2003, 09:08 AM
Member Group: Members Posts: 478 Joined: 30-March 03 From: Vacaville, CA Member No.: 497 Region Association: Northern California |
I think that it is old out of round tires. Yes, that is my final answer. My car sat on old tires for 10 years. As soon as I started driving it, right around 68-72 MPH started to shake violently. The quick fix I came up with was to just drive faster (IMG:style_emoticons/default/biggrin.gif) , but I did end up buying new tires a few weeks later. As for your quick fix, I can guess you either have another set of wheels/tires, drove slower, or drove faster!
-Chris |
rhodyguy |
Jun 25 2003, 09:19 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,079 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
did you rotate the tires? the front ones always go away first. the rears are usually consistant.
kevin |
Bleyseng |
Jun 25 2003, 09:31 AM
Shocks are bad.....Alignment is bad...ball joints are going....loose bolts on A-arms....out or round tires..tires out of balance
Geoff |
Mark Henry |
Jun 25 2003, 10:17 AM
Bruce is close enough!
Bruce, you have won a new looking tire with a shifting steel belt! How would you like it shipped? (IMG:style_emoticons/default/wink.gif) Yep they are old/new tires, we drove them all last year and this spring, no problems. I think it was the wife’s radical swerving to miss a deer last month that did in the tire. I was hoping to get the rest of the year out of these tires and buy wider sticky tires and new rims over next winter. Oh well. I might just replace the one tire till I have the coin for my new wheels. (IMG:style_emoticons/default/dance.gif) |
Bruce Allert |
Jun 25 2003, 10:34 AM
I know how that is! I was hard pressed to accept that my fine looking tires were bad. Even after puting new ones on I still had vibration. Thats where REX at Americas Tire Shop came into the picture.
Right on REX (IMG:style_emoticons/default/smilie_pokal.gif) bruce |
Lo-Fi Version | Time is now: 13th May 2024 - 06:37 AM |
