Any tips for rear window rattle without seat removal? |
carcus |
Sep 5 2016, 11:02 PM
Member Group: Members Posts: 223 Joined: 16-March 16 From: Colorado Springs Member No.: 19,760 Region Association: Rocky Mountains |
I get some rear window rattle, the glass on the back wall under the seat back pad. I was thinking of putting something behind the seat back pad near the lower part of the window to quiet it down. When I put the seats in I put silicone under the lower part of the rear window and I put a new seal on the outer part near the rear trunk where it meets the rear window. I still have a little glass on metal sound. Granted, our roads suck here but looking for options. Not taking the rear seat or back pad out again.
Darren C |
Sep 6 2016, 01:27 AM
Member Group: Members Posts: 392 Joined: 26-December 14 From: Chichester UK Member No.: 18,255 Region Association: England |
You kinda know the answer to your own question....
Seats out Trim out Glass out Clean up New butyl seal Refit glass Trim & seats back in It shouldn't take more than an afternoon. Anything else is futile. |
shoguneagle |
Sep 6 2016, 05:26 AM
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
Agree and the glass sets on a couple of rubber pad located on the bottom of the window
GaroldShaffer |
Sep 6 2016, 06:49 AM
You kinda know the answer to your own question.... Seats out Trim out Glass out Clean up New butyl seal Refit glass Trim & seats back in It shouldn't take more than an afternoon. Anything else is futile. (IMG:style_emoticons/default/agree.gif) It can be a PITA but when you have a free afternoon just do the above, you will be happy that you did. Besides a rattling rear window means water can now get it and start to collect at the lower firewall / floor pan. |
carr914 |
Sep 6 2016, 08:25 AM
Racer from Birth Group: Members Posts: 118,670 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
You kinda know the answer to your own question.... Seats out Trim out Glass out Clean up New butyl seal Refit glass Trim & seats back in It shouldn't take more than an afternoon. Anything else is futile. (IMG:style_emoticons/default/agree.gif) It can be a PITA but when you have a free afternoon just do the above, you will be happy that you did. Besides a rattling rear window means water can now get it and start to collect at the lower firewall / floor pan. I disagree - this is a simple job. I can have the entire interior out of a 914 in about 10 minutes. If someone can't take the seats & backpad out, they shouldn't have a car they play with. |
Mikey914 |
Sep 6 2016, 10:16 AM
The rubber man Group: Members Posts: 12,668 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Got the parts you need here -
https://shop.914rubber.com/rear-window-rese...m?categoryId=-1 Both rubber strips and the butyl $20 |
davesprinkle |
Aug 28 2018, 07:50 PM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
Silicone doesn't belong anywhere on a car. Ever.
Larmo63 |
Aug 28 2018, 08:18 PM
Seats out, belts out, roll bar pads off, and back pad out, glass out, clean everything, easy. I just did this recently.
Do it right. Do it once. You will have peace of mind and a solid roll bar window. It's a bit of a PITA, but worth it. |
Aug 28 2018, 08:33 PM
"Sorry, we could not find any matches for a pillar. The following stopword(s): [a] were excluded from the search. A stopword is a word such as "the" or "some" that is too common to be considered a keyword. Please check your spelling or search using different keyword." @Mikey914 (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/type.gif) PS: Yes, i know this is from 2016 ... |
PanelBilly |
Aug 28 2018, 10:16 PM
914 Guru Group: Members Posts: 5,807 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Fold a book of matches and stick them between the glass and the frame. My car had this fix for so many years, the color faded on the matchbook.
Jonathan Livesay |
Aug 28 2018, 10:29 PM
Senior Member Group: Members Posts: 741 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
You kinda know the answer to your own question.... Seats out Trim out Glass out Clean up New butyl seal Refit glass Trim & seats back in It shouldn't take more than an afternoon. Anything else is futile. (IMG:style_emoticons/default/agree.gif) But be careful that's how this started. |
Mikey914 |
Aug 29 2018, 12:13 AM
Yes this is pretty easy to do. everything you need to install is here -
https://shop.914rubber.com/Engine-Deck-Lid-Seal-914EDLS.htm For $20 However, While you are there may want to replace the engine deck lid seal that pushes against it at the outside base. https://shop.914rubber.com/Engine-Deck-Lid-Seal-914EDLS.htm Attached image(s) |
thelogo |
Aug 29 2018, 12:54 AM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
Fold a book of matches and stick them between the glass and the frame. My car had this fix for so many years, the color faded on the matchbook. Your the man this mod is going in tomarro on my car (IMG:style_emoticons/default/smoke.gif) |
Triaddave |
Aug 31 2018, 01:31 PM
Member Group: Members Posts: 244 Joined: 31-December 03 From: olympia,wa Member No.: 1,478 |
It may sound lame but I had a pack of matches stuck in the window for years, worked fine and it was cheap and available.
Triaddave |
Aug 31 2018, 01:32 PM
EdwardBlume |
Aug 31 2018, 01:38 PM
Dad stuck a sponge in there. Worked.
AZBanks |
Aug 31 2018, 02:27 PM
Senior Member Group: Members Posts: 1,063 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region |
Silicone doesn't belong anywhere on a car. Ever. ??? https://i.pinimg.com/736x/88/9a/e0/889ae04e...er-porsche-.jpg |
VegasRacer |
Aug 31 2018, 02:52 PM
ELVIRA Group: Benefactors Posts: 8,509 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
Fold a book of matches and stick them between the glass and the frame. My car had this fix for so many years, the color faded on the matchbook. Yup. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/agree.gif) A strategically placed matchbook wedge also works to keep 8 track tapes from cross-tracking. |
thelogo |
Aug 31 2018, 03:43 PM
Fold a book of matches and stick them between the glass and the frame. My car had this fix for so many years, the color faded on the matchbook. Yup. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/agree.gif) A strategically placed matchbook wedge also works to keep 8 track tapes from cross-tracking. Sorry man but 8 tracks Attached image(s) |
jdamiano |
Aug 31 2018, 07:08 PM
Member Group: Members Posts: 335 Joined: 18-March 18 From: Jacksonville Member No.: 21,981 Region Association: South East States |
My car had a folded up business card keeping the raddle down when I purchased it. I think it was a divorce lawyers card. I quickly spent the couple hours and 20 or so bucks following the introductions found on this site to fix right. Not a hard job.
Lo-Fi Version | Time is now: 17th May 2024 - 02:53 PM |
