Any tips for rear window rattle without seat removal? |
EdwardBlume |
Sep 1 2018, 06:28 AM
My car had a folded up business card keeping the raddle down when I purchased it. I think it was a divorce lawyers card. I quickly spent the couple hours and 20 or so bucks following the introductions found on this site to fix right. Not a hard job. (IMG:style_emoticons/default/agree.gif) Its not a hard job at all. The only sticky part is.... well, the sticky part.... |
Sep 1 2018, 06:36 AM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Do you have to remove the top targa bar pad. If so, that’s the only pita part about it.
Mikey914 |
Sep 2 2018, 04:54 AM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I've done it without/
Sep 2 2018, 05:36 AM
ConeDodger |
Sep 2 2018, 08:21 AM
Apex killer! Group: Members Posts: 23,611 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
The answer to the question the OP asked:
(first I’ll paraphrase the question) can I do the job but skip a bunch of important steps? Yes. You can get rid of the rattle without taking out the interior. Sell the car. (IMG:style_emoticons/default/blink.gif) |
Sep 2 2018, 09:55 AM
The answer to the question the OP asked: (first I’ll paraphrase the question) can I do the job but skip a bunch of important steps? Yes. You can get rid of the rattle without taking out the interior. Sell the car. (IMG:style_emoticons/default/blink.gif) Seats come out in 10 seconds. add a minute or 2 if its a fixed passenger seat.Unscrew the engine lid pull knob down by the ebrake cable. Backpad is 4 screws after you pop out the back pad light. Upper belts are 1 bolt each then 1 screw each for side bolters(2 on the driver side for the hanger. I think it might take 10 -15 minutes total and if you haven't done it before, you will be surprised by how much junk gets trapped on the floor behind the back pad. Remember, the back pad pulls down and away from the fire wall. |
raynekat |
Sep 2 2018, 10:04 AM
Advanced Member Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
The answer to the question the OP asked: (first I’ll paraphrase the question) can I do the job but skip a bunch of important steps? Yes. You can get rid of the rattle without taking out the interior. Sell the car. (IMG:style_emoticons/default/blink.gif) Seats come out in 10 seconds. add a minute or 2 if its a fixed passenger seat.Unscrew the engine lid pull knob down by the ebrake cable. Backpad is 4 screws after you pop out the back pad light. Upper belts are 1 bolt each then 1 screw each for side bolters(2 on the driver side for the hanger. I think it might take 10 -15 minutes total and if you haven't done it before, you will be surprised by how much junk gets trapped on the floor behind the back pad. Remember, the back pad pulls down and away from the fire wall. Perfect explanation of the procedure.... |
ConeDodger |
Sep 2 2018, 06:15 PM
The answer to the question the OP asked: (first I’ll paraphrase the question) can I do the job but skip a bunch of important steps? Yes. You can get rid of the rattle without taking out the interior. Sell the car. (IMG:style_emoticons/default/blink.gif) Seats come out in 10 seconds. add a minute or 2 if its a fixed passenger seat.Unscrew the engine lid pull knob down by the ebrake cable. Backpad is 4 screws after you pop out the back pad light. Upper belts are 1 bolt each then 1 screw each for side bolters(2 on the driver side for the hanger. I think it might take 10 -15 minutes total and if you haven't done it before, you will be surprised by how much junk gets trapped on the floor behind the back pad. Remember, the back pad pulls down and away from the fire wall. Perfect explanation of the procedure.... Yes. I could explain the procedure too. My point is if you know and he knew, that you need to remove the interior to reseal the rear window and you go to this effort to avoid the prep work, you need to sell the car because this goes no where. |
Jonathan Livesay |
Sep 2 2018, 07:33 PM
Senior Member Group: Members Posts: 742 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
The answer to the question the OP asked: (first I’ll paraphrase the question) can I do the job but skip a bunch of important steps? Yes. You can get rid of the rattle without taking out the interior. Sell the car. (IMG:style_emoticons/default/blink.gif) Seats come out in 10 seconds. add a minute or 2 if its a fixed passenger seat.Unscrew the engine lid pull knob down by the ebrake cable. Backpad is 4 screws after you pop out the back pad light. Upper belts are 1 bolt each then 1 screw each for side bolters(2 on the driver side for the hanger. I think it might take 10 -15 minutes total and if you haven't done it before, you will be surprised by how much junk gets trapped on the floor behind the back pad. Remember, the back pad pulls down and away from the fire wall. Yes, you could easily make back $2-3 in loose and grody looking change. |
gereed75 |
Sep 2 2018, 08:37 PM
Senior Member Group: Members Posts: 1,259 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
And just maybe you could avoid being a DAPO
Lo-Fi Version | Time is now: 7th June 2024 - 09:59 AM |
