FLAT TOW your 914! Tow Bracket, * New Product * |
914werke |
Sep 9 2016, 05:04 PM
"I got blisters on me fingers" Group: Members Posts: 10,041 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Made specifically for the 914, this is a heavy duty steel angle cross bar design rather than flat bar found on previous product.
This provides key advantages: 1st. Strength. 2nd. Geometry. The new x-bar also allows the pin lynch points to be about 1" lower then before (while actually improving its strength). 3rd. Convenience! The bar now has mount points to carry the included bolts & spacers. Because it has its pin/bar mounting location slightly lower, allows for use with "LE" style FG spoilers without their removal (with properly setup hitch & bar geometry!). The V style adj. tow bar is recommended again for its convenience, as you can fold it up & throw the whole kit in the either trunk!. The Bar is made from .375 steel & still relatively light weight. Lastly it also has additional mount points for chassis safety chains /cables. FITS ALL 914's regardless of MY! Designed to use the inexpensive Adjustable V tow bar - NO Adapters necessary! *If you still run the OE steel valance it will still be necessary to remove before use. The Tow bar & lights (pictured below) can be provided/purchased as a bundle for your convenience, but are readily available from many sources. 914 chassis mount bar HERE 914 Tow Kit (mount bar & adj. V hitch bar + lights) inquire Magnetic Tow lights HERE (IMG:style_emoticons/default/bye1.gif) Attached thumbnail(s) Attached image(s) |
914werke |
Aug 8 2018, 01:47 PM
914werke |
Aug 8 2018, 01:54 PM
Attached image(s) |
914werke |
Aug 22 2018, 07:48 PM
914werke |
May 30 2019, 10:19 AM
bretth |
May 30 2019, 11:52 AM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
Do you need to lock the front wheels straight somehow when using this? I may need one of these soon.
914werke |
Jun 3 2019, 10:46 AM
Do you need to lock the front wheels straight somehow when using this? I may need one of these soon. Nope in fact the opposite. You want the steer wheel unlocked so the wheels track with the direction that the tow vehicle is taking it. (IMG:style_emoticons/default/smile.gif) |
loux951 |
Aug 2 2019, 08:35 AM
NOLA 914 Group: Members Posts: 35 Joined: 30-May 03 From: New Orleans, LA Member No.: 758 Region Association: South East States |
PM Sent
914werke |
Sep 9 2019, 12:37 PM
Lo-Fi Version | Time is now: 5th May 2024 - 06:21 AM |
