Fuel check valve and the 3port fuel pump |
brant |
Sep 10 2016, 07:54 AM
914 Wizard Group: Members Posts: 11,624 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I think there must be a check valve built into the 3 port djet pump
I believe mine is not working (Hard starting symptoms) Has anyone pulled theirs apart? Pictures or a thread? I'm also wondering if adding an in line check valve would work? |
brant |
Sep 10 2016, 08:48 AM
Ok it's just a bypass
So has anyone ever added a check valve? I imagine it adds some restriction to the system What would be the other reasons this is a bad idea? I'm having a hard start situation If I turn the key it is a 25 second crank before it starts If I turn the key off/on about 5 times and let the pump prime Then it will start instantly So I'm loosing pressure I figure it's either a bad/leaky injector or a situation where the system s draining back to the tank I will test fuel pressure and injectors when I get home But might also test the drain-back by adding a check valve? |
sixnotfour |
Sep 10 2016, 08:56 AM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Ok it's just a bypass So has anyone ever added a check valve? I imagine it adds some restriction to the system What would be the other reasons this is a bad idea? I'm having a hard start situation If I turn the key it is a 25 second crank before it starts If I turn the key off/on about 5 times and let the pump prime Then it will start instantly So I'm loosing pressure I figure it's either a bad/leaky injector or a situation where the system s draining back to the tank I will test fuel pressure and injectors when I get home But might also test the drain-back by adding a check valve? filters dirty or pumps bad , use a 2port later pump..relax |
Lo-Fi Version | Time is now: 17th May 2024 - 03:18 PM |
