Fuel check valve and the 3port fuel pump |
brant |
Sep 10 2016, 07:54 AM
914 Wizard Group: Members Posts: 11,624 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I think there must be a check valve built into the 3 port djet pump
I believe mine is not working (Hard starting symptoms) Has anyone pulled theirs apart? Pictures or a thread? I'm also wondering if adding an in line check valve would work? |
sixnotfour |
Sep 13 2016, 08:25 PM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
put a 2 port pump in,, problem gone..the roller vane pump needs to be lower for feed ..total restoration not necessary at this point ..drive it like you stole it...
you are correct..like it needs a check valve ,,really you need the proper pump for where you put it.. In fact I send you one free ..I don't do type 4sale anymore....LMK |
brant |
Sep 13 2016, 09:02 PM
put a 2 port pump in,, problem gone..the roller vane pump needs to be lower for feed ..total restoration not necessary at this point ..drive it like you stole it... you are correct..like it needs a check valve ,,really you need the proper pump for where you put it.. In fact I send you one free ..I don't do type 4sale anymore....LMK I will buy one from you if you have a spare.. I'm thinking the relocation is part of my problem |
Lo-Fi Version | Time is now: 17th May 2024 - 04:10 PM |
