WTB: 1974 1.8 Mass Air Flow (MAF) Sensor |
andrewvolsen |
Sep 11 2016, 12:48 AM
Newbie Group: Members Posts: 44 Joined: 6-December 09 From: Santa Barbara Member No.: 11,099 Region Association: Central California |
Just like the title says, looking for a 1974 1.8 MAF. Please let me know if you have one available, I need this to get my 914 back on the road.
andrewvolsen |
Sep 11 2016, 11:41 AM
Part number visible on top of the plastic electronics cover of the MAF is 0 280 200 001.
djway |
Sep 11 2016, 05:25 PM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
Part number visible on top of the plastic electronics cover of the MAF is 0 280 200 001. You can rebuild these on your own. I took out the air temp sender and cleaned the contacts and got a good reading then I adjusted the height of the potentiometer wiper to get a clean unworn area. The prior owner had really messed with the spring resistance to cover up a bunch or air leaks so I used an air fuel ratio gauge to set the spring resistance to give me 14.7 reading at 3000 rpm on the highway. |
andrewvolsen |
Sep 11 2016, 05:43 PM
I opened it up last night to try cleaning the resistor track and contacts and adjusting the height of the wiper arm to contact fresh resistor track. Unfortunately, there seem to be a number of dead spots in the resistor track where resistance read at the connector pins (I forget the pin numbers) jumps to infinite/open circuit. I tried adjusting it for about an hour, but was unable to get it set in a way that eliminated the dead spots. It looks like a PO tried to clean the resistor track at some point in the past and damaged it (scratch marks), so I think it may be beyond saving.
I am considering just finding a core AFM and sending it in to one of the Bosch AFM rebuild services so I know I have a good working unit. Does anyone have any thoughts on this approach? |
bdstone914 |
Sep 11 2016, 06:41 PM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have one but have to check if it is a75 or 74.
djway |
Sep 12 2016, 02:02 AM
I opened it up last night to try cleaning the resistor track and contacts and adjusting the height of the wiper arm to contact fresh resistor track. Unfortunately, there seem to be a number of dead spots in the resistor track where resistance read at the connector pins (I forget the pin numbers) jumps to infinite/open circuit. I tried adjusting it for about an hour, but was unable to get it set in a way that eliminated the dead spots. It looks like a PO tried to clean the resistor track at some point in the past and damaged it (scratch marks), so I think it may be beyond saving. I am considering just finding a core AFM and sending it in to one of the Bosch AFM rebuild services so I know I have a good working unit. Does anyone have any thoughts on this approach? I found a bunch of old baywindow 2.0 AFM's cheap and I got one with a nice board and just swapped them. I made an air fuel ratio meter that I could clamp onto the stock exhaust pipe. I used that to set the spring tension so that I ran at 14.7 at 3000 rpm on the highway. Was an easy fix. |
bretth |
Sep 12 2016, 08:13 AM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
Is the 1.8 914 and 2.0 bus the same circuit board? I know Automotion sells a rebuilt 1.8 for under $150 if I remember right. Was in their catalog but can't find it online at the moment.
Brett I found a bunch of old baywindow 2.0 AFM's cheap and I got one with a nice board and just swapped them. I made an air fuel ratio meter that I could clamp onto the stock exhaust pipe. I used that to set the spring tension so that I ran at 14.7 at 3000 rpm on the highway. Was an easy fix. |
andrewvolsen |
Sep 12 2016, 10:11 AM
Brett,
I was able to find the rebuilt 1974 1.8 MAFs through that catalog. The image shows a sticker for "Fuel Injection Corp" as the actual re-builder of the units. Have you purchased one of these before? Was it a quality rebuild? |
Lo-Fi Version | Time is now: 9th June 2024 - 07:15 PM |
