Need Help Identifying Struts |
amfab |
Sep 14 2016, 08:58 AM
Member Group: Members Posts: 393 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None |
Hi,
I am looking to buy some used 3" spacing 911 struts but I want the late wedge-pin style ball joint bolts. The struts I am looking to buy are: Boge 1-0211-32-173-0 Porsche part # 911-341-080-02 I cannot find that Porsche part number. I am concerned that they are the early style and the PET only shows the later part number. The seller sent me these picts of the bottom of the struts. Can anyone identify early or late from the picts? -Andrew Attached thumbnail(s) |
gms |
Sep 14 2016, 10:54 PM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
The picture you show is a 1969 or later strut, the early struts look totally different and will not attach to a post 1969 a-arm (see below)
jcd914 |
Sep 14 2016, 11:03 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
If by "early or late" you want to know if they are early (69 to 72) pinch style or late (73 to 89) taper pin style, those are late taper pin struts.
Black paint would infer they are Boge struts but they could be repainted. Jim |
914Sixer |
Sep 15 2016, 06:25 AM
914 Guru Group: Members Posts: 8,882 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Mid 911 struts are split at the base and use a pinch bolt. Late 911 are solid base and use v shaped wedgepin. Since there is no split at the base, the struts are late style and use the same ball joint as the 914.
pencap914 |
Jan 23 2021, 11:26 AM
Member Group: Members Posts: 75 Joined: 16-April 06 Member No.: 5,872 Region Association: Northern California |
I too am searching for a pair of struts with 3" spacing and later "wedge pin" style.
I came across these from a seller, but it looks like these are the pinch bolt...right? Attached thumbnail(s) |
Montreal914 |
Jan 23 2021, 12:10 PM
Senior Member Group: Members Posts: 1,560 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
^^^ Yes, these are the pinch style.
Below is a pin style, disregard the green paint, I had mine refreshed and wanted them green (IMG:style_emoticons/default/biggrin.gif) . Good luck with your search (IMG:style_emoticons/default/smile.gif) |
JeffBowlsby |
Jan 23 2021, 12:37 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
You may be looking for these. Wedge bolts, 3 in caliper spacing. Straight arms, they fit Bilstein dampers.
I would consider offers for the set, PM if interested. Can include new wedge bolts/roll pins. Attached thumbnail(s) |
mepstein |
Jan 23 2021, 03:13 PM
914-6 GT in waiting Group: Members Posts: 19,273 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
pencap914 |
Jan 25 2021, 03:10 AM
^^^ Yes, these are the pinch style. Below is a pin style, disregard the green paint, I had mine refreshed and wanted them green (IMG:style_emoticons/default/biggrin.gif) . Good luck with your search (IMG:style_emoticons/default/smile.gif) Thanks for clarifying this! looking good. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 07:19 PM |
