6 Pages V « < 4 5 6
> New GB CHT probe NLA closes Oct 29th- if you have the code use today, Code is expiring TODAY $34 we get to get 50 PN 0280130012
Mikey914
post Oct 29 2016, 11:29 AM
Post #101
The rubber man
Thanks all, thin k I have PM'd all the GB price discount code.
This special price ends TODAY !
Bump this thread if you want the special price!
Firstcar
post Oct 29 2016, 11:47 AM
Post #102
Obsessive amateur mechanic
QUOTE(Mikey914 @ Oct 29 2016, 01:29 PM) *
Mark,
Didn't get a PM from you - post #96.
-Scott
MartyYeoman
post Oct 29 2016, 03:24 PM
Post #103
Sensor arrived.
Thanks, Mark (IMG:style_emoticons/default/pray.gif)
Wyvern
post Oct 29 2016, 09:44 PM
Post #104
Got mine today ... thank you .
Any quick tips for removal and install.
Was thinking a 13mm deep socket "slightly modified"
or bending a 13mm wrench .
Mueller
post Oct 29 2016, 10:59 PM
Post #105
914 Freak!
Got mine, thanks for doing this.
sofi2t81
post Oct 30 2016, 05:09 AM
Post #106
Region Association: Germany
Hello Mark,
Didn't receive a PM. Post no. 99.
thanks
Peter.
DRPHIL914
post Oct 30 2016, 05:18 AM
Post #107
Dr. Phil
Ordered and paid! (IMG:style_emoticons/default/beerchug.gif)
Mikey914
post Oct 30 2016, 05:48 AM
Post #108
The rubber man
PMs resent.
Let me know if you have any problems ordering, but code sound work to the 31st.
Mark
McMark
post Oct 30 2016, 09:12 AM
Post #109
914 Freak!
The 914Rubber production CHT units will have the correct connector. The unit pictured is just a mockup.
For the benefit of other members, the red/blue/yellow colored connectors are a travesty of automotive wiring. They are NOT sufficient for ANY automotive use. Use correct double crimp connectors with heat shrink.
Mikey914
post Oct 30 2016, 10:12 AM
Post #110
The rubber man
Yes it was just a mock up. The production ones have the correct connectors.
malcolm2
post Oct 30 2016, 10:19 AM
Post #111
QUOTE(Wyvern @ Oct 29 2016, 10:44 PM) *
The wire does get in the way. But your method should do the trick.
It has been too long. Should we use spark plug type anti sieze?
Jett
post Oct 30 2016, 10:58 AM
Post #112
Thanks Mark, ordered this morning for our 73 1.7.
Has anyone installed the sensor in a 73 2.0/4? Does it work well?
Mikey914
post Oct 31 2016, 06:08 AM
Post #113
The rubber man
QUOTE(malcolm2 @ Oct 30 2016, 09:19 AM) *
Definitely used at least a deep socket. A box wrench on the end of a spark plug socket will allow you to snug it up. You don't need a bunch of pressure as it's really not going anywhere.
Last day code is good is today use it or loose it.
GOT9146
post Apr 20 2017, 12:25 PM
Post #114
Any idea when more will be available?
Mikey914
post Apr 20 2017, 05:22 PM
Post #115
The rubber man
IN stock now
http://shop.914rubber.com/Cylinder-Head-Te...m?categoryId=-1
xicema17x
post May 18 2017, 03:14 PM
Post #116
QUOTE(Mikey914 @ Apr 20 2017, 04:22 PM) *
Hi Mark, I saw a bunch of responses for 71-73 914s, but just wanted to confirm first, would these work for 76 2.0 914 as well?
Many Thanks,
Jason
Mikey914
post May 18 2017, 11:20 PM
Post #117
The rubber man
Yep, no problem on the 76.
xicema17x
post May 19 2017, 11:45 AM
Post #118
QUOTE(Mikey914 @ May 18 2017, 10:20 PM) *
Thanks so much, I'll be putting an order in today! Much appreciated...
Jason
6 Pages V « < 4 5 6
- Lo-Fi Version Time is now: 2nd April 2026 - 03:40 PM
