VDO gauges, PIC: remove the bezel? |
sechszylinder |
Jun 25 2003, 05:56 AM
Member Group: Members Posts: 247 Joined: 9-April 03 From: /earth/europe/germany/berlin Member No.: 545 Region Association: None |
hilow folks,
i found it very easy to remove the outer ring from the gauges, but reinstalling the ring is another story. vdo has a special tool like a can opener and they always use a new outer ring when rebuilding a gauge. timo; here is another guy from old europe (IMG:style_emoticons/default/smilie_flagge6.gif) benno |
914Timo |
Jun 25 2003, 06:17 AM
******* Group: Members Posts: 743 Joined: 13-January 03 From: Finland Member No.: 137 Region Association: Europe |
Hi Benno (IMG:style_emoticons/default/wavey.gif)
Really nice to notice that here are other european also. (IMG:style_emoticons/default/mueba.gif) |
Lawrence |
Jun 25 2003, 07:17 AM
QUOTE Lawrence...Some might say that you have wayyy too much time on your hands (not me)-I love the mounted dials and callipers -better than deer antlers anyday! -How did you get the needle to stay on the red line? Those were some of the awards for last year's Mid US Ramble, held in Oklahoma. The gauges were completely disassembled, cleaned, and then gutted so that I could superglue the pieces. The fuel gauge is full, 5600 rpm, speedo is at 94 mph. The odometer was set at 70914, and the tripmeter was 9146. back on topic... It's amazing how much clearer the gauges are when you remove the glass for cleaning. The gauges aren't perfectly sealed in the back, and 30+ years of air contaminants cloud them up. |
thesey914 |
Jun 25 2003, 08:30 AM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
QUOTE(Lawrence @ Jun 25 2003, 05:17 AM) The fuel gauge is full, 5600 rpm, speedo is at 94 mph. The odometer was set at 70914, and the tripmeter was 9146. Nice touch (IMG:style_emoticons/default/smoke.gif) TIMO: Does the needle just pull off, in order to stick the new increments on? Thanks -James |
Jun 25 2003, 11:22 AM
Resident German Group: Admin Posts: 41,634 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(thesey914 @ Jun 25 2003, 02:48 AM) Andy..saw this on the 'Bay -is this what you mean? nope, that one has only ONE light for both turn signals, i need one with a light for left and right separately, but with a black center not a silver center. for some reason, i thought they were out there, but maybe not ... Andy |
914Timo |
Jun 26 2003, 12:41 AM
QUOTE Does the needle just pull off, in order to stick the new increments on? Yes, before removing the needle I checked the end position. Then I sticked the new increments and installed the needle carefully to the same position. |
Jun 26 2003, 03:39 PM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
QUOTE(SirAndy @ Jun 24 2003, 02:54 PM) was there a factory Tach with a black center bezel AND 2 lights for the turn signals? Not a 914 tach set up like that. The single indicator light came in at the same time as the black center. You may be able to find a 911 tach with both. Won't help with your current motor, but should work on the next one... (IMG:style_emoticons/default/wink.gif) --DD |
Lo-Fi Version | Time is now: 13th May 2024 - 06:06 AM |
