Installing seats on the Frame? |
dgraves |
Sep 18 2016, 03:20 PM
1974 914 2.0 Group: Members Posts: 180 Joined: 6-June 16 From: Montana Member No.: 20,076 Region Association: Rocky Mountains |
I just received my new Renegade Seats to replace the after market seats and I am having trouble getting the seats to slide smoothly on the frame. The states are binding on the frame. Is there a specific width that the rails have to be adjusted on the seat. I really need some help on this one.
Thank you. Dan. |
Cracker |
Sep 18 2016, 03:39 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
I don't quite understand the exact problem...take a picture and share? I had a 914 with the renegade seats (really comfy too!) and they were fully adjustable with no binding.
Tony I just received my new Renegade Seats to replace the after market seats and I am having trouble getting the seats to slide smoothly on the frame. The states are binding on the frame. Is there a specific width that the rails have to be adjusted on the seat. I really need some help on this one. Thank you. Dan. |
tygaboy |
Sep 18 2016, 05:41 PM
914 Guru Group: Members Posts: 5,295 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
One of my seats (stock) was tough to slide. Seemed to be binding. I pulled everything out and determined the frame that bolts to the floor was bent. $25 at the local Porsche salvage yard for a replacement and all's well.
dgraves |
Sep 18 2016, 08:42 PM
The frame doesn't seem to be bent. I've leveled the sliders on the seat to make sure that the slider frames are level back to front. I sand blasted the frame and the slider so the metal on metal is smooth. Should I be greasing this?
dgraves |
Sep 18 2016, 08:43 PM
The frame doesn't seem to be bent. I've leveled the sliders on the seat to make sure that the slider frames are level back to front. I sand blasted the frame and the slider so the metal on metal is smooth. Should I be greasing this?quote name='Cracker' date='Sep 18 2016, 03:39 PM' post='2400071']
I don't quite understand the exact problem...take a picture and share? I had a 914 with the renegade seats (really comfy too!) and they were fully adjustable with no binding. Tony [quote name='dgraves' post='2400064' date='Sep 18 2016, 05:20 PM'] I just received my new Renegade Seats to replace the after market seats and I am having trouble getting the seats to slide smoothly on the frame. The states are binding on the frame. Is there a specific width that the rails have to be adjusted on the seat. I really need some help on this one. Thank you. Dan. [/quote] [/quote] |
Mike Bellis |
Sep 18 2016, 09:25 PM
Have you measured to make sure the rails are square (parallel) to each other?
dgraves |
Sep 20 2016, 08:25 PM
Thanks for the feedback. I finally tracked down a 1/16 of an inch bend in one rail. It's now sliding...but have another question. See the attached photo. Is this the correct location for this large relay on a '74 beneath the passenger seat. It seems that the seat is possibly hitting this.
Attached thumbnail(s) |
Cracker |
Sep 20 2016, 08:48 PM
Good to hear...with 914's, it usually something like "that"! Regarding the relay...I don't know - I have a race car and don't have that part. Sorry.
Tony |
GaroldShaffer |
Sep 20 2016, 10:17 PM
Thanks for the feedback. I finally tracked down a 1/16 of an inch bend in one rail. It's now sliding...but have another question. See the attached photo. Is this the correct location for this large relay on a '74 beneath the passenger seat. It seems that the seat is possibly hitting this. Yes that is the correct spot for that relay. |
Mike Bellis |
Sep 20 2016, 11:29 PM
Yank the relay and connect the two large yellow wires (starter) together. Unless you like the seatbelt warning system...
dgraves |
Sep 21 2016, 10:06 PM
Mike Bellis |
Sep 21 2016, 10:38 PM
Mike, so all the wires on the large relay are associated with the seat belts except the two large yellow ones? Really? Yank the relay and connect the two large yellow wires (starter) together. Unless you like the seatbelt warning system... The relay interrupts the starter unless the seatbelts are fastened. Many time the system fails and you are stranded wondering why it won't crank. |
dgraves |
Sep 22 2016, 08:43 PM
Many thanks, Mike.
Lo-Fi Version | Time is now: 19th May 2024 - 08:36 AM |
