dgraves
Sep 18 2016, 03:20 PM
I just received my new Renegade Seats to replace the after market seats and I am having trouble getting the seats to slide smoothly on the frame. The states are binding on the frame. Is there a specific width that the rails have to be adjusted on the seat. I really need some help on this one.
Thank you. Dan.
Cracker
Sep 18 2016, 03:39 PM
I don't quite understand the exact problem...take a picture and share? I had a 914 with the renegade seats (really comfy too!) and they were fully adjustable with no binding.
Tony
QUOTE(dgraves @ Sep 18 2016, 05:20 PM)
Thank you. Dan.
tygaboy
Sep 18 2016, 05:41 PM
One of my seats (stock) was tough to slide. Seemed to be binding. I pulled everything out and determined the frame that bolts to the floor was bent. $25 at the local Porsche salvage yard for a replacement and all's well.
dgraves
Sep 18 2016, 08:42 PM
The frame doesn't seem to be bent. I've leveled the sliders on the seat to make sure that the slider frames are level back to front. I sand blasted the frame and the slider so the metal on metal is smooth. Should I be greasing this?
dgraves
Sep 18 2016, 08:43 PM
The frame doesn't seem to be bent. I've leveled the sliders on the seat to make sure that the slider frames are level back to front. I sand blasted the frame and the slider so the metal on metal is smooth. Should I be greasing this?quote name='Cracker' date='Sep 18 2016, 03:39 PM' post='2400071']
Tony
[quote name='dgraves' post='2400064' date='Sep 18 2016, 05:20 PM']
Thank you. Dan.
[/quote]
[/quote]
Mike Bellis
Sep 18 2016, 09:25 PM
Have you measured to make sure the rails are square (parallel) to each other?
dgraves
Sep 20 2016, 08:25 PM
Thanks for the feedback. I finally tracked down a 1/16 of an inch bend in one rail. It's now sliding...but have another question. See the attached photo. Is this the correct location for this large relay on a '74 beneath the passenger seat. It seems that the seat is possibly hitting this.
Cracker
Sep 20 2016, 08:48 PM
Good to hear...with 914's, it usually something like "that"! Regarding the relay...I don't know - I have a race car and don't have that part. Sorry.
Tony
GaroldShaffer
Sep 20 2016, 10:17 PM
QUOTE(dgraves @ Sep 20 2016, 09:25 PM)
Yes that is the correct spot for that relay.
Mike Bellis
Sep 20 2016, 11:29 PM
Yank the relay and connect the two large yellow wires (starter) together. Unless you like the seatbelt warning system...
dgraves
Sep 21 2016, 10:06 PM
Mike, so all the wires on the large relay are associated with the seat belts except the two large yellow ones? Really?
QUOTE(Mike Bellis @ Sep 20 2016, 11:29 PM)
Mike Bellis
Sep 21 2016, 10:38 PM
QUOTE(dgraves @ Sep 21 2016, 09:06 PM)
The relay interrupts the starter unless the seatbelts are fastened. Many time the system fails and you are stranded wondering why it won't crank.
dgraves
Sep 22 2016, 08:43 PM
Many thanks, Mike.
QUOTE(Mike Bellis @ Sep 21 2016, 10:38 PM)
